bizhub C6500 with C- 5003
  • Darius
    • Aug 2011
    • 13
    [Dead] bizhub C6500 with C- 5003
    any udeeas? any solutions?
  • Gaffers01
    • May 2011
    • 335
    Re: bizhub C6500 with C- 5003
    I havent come across this error code before but this is what it says in the manual.
    Communication
    abnormality
    C-5003 Conveyance drive board (CDB)
    24VDC abnormality.
    Abnormality signal of 24VDC for
    CVD was detected.
    DC power unit/2 (DCPS/2)
    (CDB)
    Have you changed any boards or had any boards out, as i would check all connectors are plugged in.
    • Darius
      • Aug 2011
      • 13
      Communication
      abnormality
      24VDC abnormality.
      CVD was detected.
      (CDB)
      I pulled out the fuser unit and start with door open. i receive C-2221!!!!
      • Mick01
        • Nov 2012
        • 362
        It appears you have an issue with the 24v line. Check you are getting 24v output from the DC power supply. Check you are getting 24v output from PRCB. Check ICP's on PRCB and CDB. Try running motors in I/O mode
        • JustManuals
          • Jan 2006
          • 9838
          I also have the frimware and the NVRAM Recovery Tool.
          Paul@justmanuals.com
