KM Bizhub 7145 with FS-114 Attached
  • Notmemate
    • Jun 2025
    [Misc] KM Bizhub 7145 with FS-114 Attached
    Hi All.
    Please can anyone tell me how the FS-114 Finisher is held in to the copier body. I have all the books/Manuals for this m/c but the info on the FS-114 is soooo minimal.
    There is a belt that appears to have dropped of the back of the finisher. I can see the cogs, just, but no way I can get at the gubbings.
    Any help is most appreciated.
  • kingarthur
    • 1337
    Re: KM Bizhub 7145 with FS-114 Attached
    there are 2 ways...if there is only you, remove the six screws that hold the stacker unit, remove the cables & earth wires, remove the stacker unit, then on the main body of the FNS, there's what appears to be a black square label at the bottom, looking directly at the FNS with the door open, it's to the right & below the staple unit, push a screwdriver against it & it'll release the catch at the back
    if there's 2 of you, just release the catch & slide the FNS towards you, but make sure you support it properly when you put it down
    • Notmemate
      Definatly King of the Castle. Finisher now on the floor!!! Could not have done it with-out you!! Thank you very,very much.
      Regards Peter
      • minimerlin
        • 851
        Regards Peter
        Hope its still in one piece on the floor..lol
        Please do not PM me without asking first.
