My customer has evidently tried to scan a document that is not permitted to be scanned and it has disabled the scan function on the 3 different machines he has. Does someone know the procedure to reset the scanner function so it works again? The machines scan/fax button is disabled. And this happened after they tried t scan a birth certificate to email for someone, when it did not work on 1 machine they went to each of the others.
Bizhub c451 Scanner Issue
Re: Bizhub c451 Scanner Issue
If you are a Konica Dealer you will probably have to open a ticket with tech support, because you will have to send back the NVRAM to Konica.
I am not sure if there policy has changed, but thats what I had to do years ago when a customer of mine tried to copy something similar.Last edited by WildbillC; 05-03-2013, 04:47 PM. -
I am not sure if there policy has changed, but thats what I had to do years ago when a customer of mine tried to copy something similar.Comment
blackcat: Master Of The Obvious =^..^=Comment
The KM Bizhub C224/C364/C454 had these problems with scanning, most of the things they scanned the printer saw as special paper (money) so it blocked. they solved this problem with a new (the latest) firmware. Maybe is this problem on more bizhubsComment
