Bizhub PRO 920 S35-01
  • Mattdlam
    • Apr 2013
    • 32
    Hi there,
    I am having an issue with abizhub pro 920 the machine continuosly gives a an S35-01 TROUBLE OCCURED, I have replaced the thermistors 1 to 4 and set the DIPSW3-1 to 0 when i restart the machine it starts up ok and when trying to print it warms up then gives the error again, i have double checked the thermistors and the lamps all seem ok as I replaced with new ones but the error does not go away. Your assistance will be greatly appreciated.
    Please note I am new to Konica Minolta so pardon my questions if they sound silly, I recently started working on KM machines from HP.
  • Albonline
    • Sep 2008
    • 1151
    Re: Bizhub PRO 920 S35-01
    Check the heater lamps to see if one is open, and the large connectors on the back of the fuser and in the main body for arc burns.
    • hachetman
      • Jul 2009
      • 96
      Make sure you didn't use the wrong lamps The manuals can be confusing and lead u to order the wrong ones, check the volts and watts on the lamps
      Steve Baker
      hachet1_12@outlook.com
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • minimerlin
          • 851
          it is easy to think the lamps are working when they are not, as they are so close and bright. Just use a meter on them. Also remember the lower fuser heater lamp in the cleaner roller.
          Please do not PM me without asking first.
          • Mattdlam
            • Apr 2013
            • 32
            Thank you so much for the quick responses, I opened up the door and put the switch on and printed realised the lower fuser lamp is not switching on but the 2 upper lamps are on will change that and test.
            Once again thanks for your input.
