Konica Minolta C452 will send but won't receive
  • Alex1
    • Oct 2012
    • 285
    Hi
    Him have a Konica Minolta Bizhub C452. I connected a fax kit. The machine is able to send but not receive can anyone help please???
  • kingarthur
    • 1369
    Re: Konica Minolta C452 will send but won't receive
    have you tried another fax lead, we used to have lots of problems with the leads that were supplied...
    • SmellsHot
      Head Tech
      • 512
      how about hooking up a handset to the line and trying that...easiest way to rule out machine......
      Might try an initialization of the fax as well.....
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • Alex1
        • Oct 2012
        • 285
        Thank you for your reply. The line is fine because we tried another fax machine to that line and worked fine.
        • Alex1
          • Oct 2012
          • 285
          Thank you for your reply. I tried another fax machine and that worked fine. Generally I always try a handset or another machine like you said it is the best way to rule out the machine.
          • 907tec
            • 434
            Is the customer using a VOIP line, or a "digital" fax line? We have had similar problems with customers using analog-to-digital converters. Try lowering the transmission speeds to 9k and test it out.
            • darry1322
              • Oct 2010
              • 817
              Is the marketing area set correctly?
              • mo0651
                • 1054
                Did you follow a set of set up instructions or did you just throw a board in?
                • Alex1
                  • Oct 2012
                  • 285
                  Perhaps that what I could have left out. Please refresh my memory on where that setting is located??
                  • Alex1
                    • Oct 2012
                    • 285
                    They are using PC fax set up, but they realised that may have been the problem.. So they ran the fax line direct from the wall socket. No good.
                    • Alex1
                      • Oct 2012
                      • 285
                      I initialised the board like I've done previously with other machines and had worked fine. This machine used to have a fax board installed, untill the board was removed so the customer ordered another board then I went out and installed it. Done the inicialisation the machine sent and received on the same day. Then the following day the machine would send but not receive.
                      • darry1322
                        • Oct 2010
                        • 817
                        The marketing area is in the machine 1 settings of service mode. If I'm remembering correctly.
                        • wseyller
                          • Sep 2012
                          • 1129
                          I had two different machine at two different locations recently have a similar issue. Sent but not receive. A bizhub 200 and a muratec fax. I carry a phone with me and hook it up the the wall. I get a good dial tone and then I go to call my cell phone and see on the caller ID that it is not the fax number. I ask the customer if they recognize the number and it turns out to be their telephone number. One place had a company come in earlier to switch some extensions around and other things. Told them to have someone check it out. Happened about a week ago and never hear back from them.
                          Of course if you try another fax machine and it works then that is a different situation.
                          Sent from my Galaxy Nexus using Tapatalk 2
