bizhub C352 Right Door (Front Pawl with handle)
    • 23008
    Is there a separate part number for the front pawl with handle, for the right door? The parts manual only shows a door assembly. Maybe there's a bulletin or parts breakdown I'm not seeing? =^..^=
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: bizhub C352 Right Door (Front Pawl with handle)
    bizhubC352_C300PartsManual-1.pdf
    do you see the part you are after?
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Do you mean the right door for the copier(where you open to access the fuser&xfer) or the lower right door for the additional paper cassette options. See attatched pic of PC-203 parts PC-203 parts.pdf Pawls are part# 4348 3053 01 (#2)and 4348 3052 01(#14). Usually #14 is the one that breaks(the one toward the front of the copier)
        • 23008
        Originally posted by Shadow
        [ATTACH]20913[/ATTACH]
        I see it, but that part is not numbered. Like my manual it appears to only come as an assembly.
        Originally posted by blazebusiness
        Do you mean the right door for the copier(where you open to access the fuser&xfer) or the lower right door for the additional paper cassette options. See attatched pic of PC-203 parts [ATTACH]20919[/ATTACH] Pawls are part# 4348 3053 01 (#2)and 4348 3052 01(#14)
        Yes, the right door of the copier.
        It was kind of difficult to get to, so I felt compelled to try to make it work. You'll like my MacGyver. The front pawl was broken into three pieces. I drilled all the pieces #59 number drill, strung together the parts onto two pieces of large paper clip wire, and liberally applied superglue. To my surprise, it's holding, but I don't know for how long.
        I've highlighted the appropriate part. Maybe somebody has a graveyard machine with this part intact?
          • 23008
          It looks kind of similar to the one on the copier. Could it be the same?
          Shadow & blazebusiness: thanks for your responses. =^..^=
          • Shadow
            • Sep 2011
            • 455
            blackcat4866,
            I am checking and cross referencing this part and the closest that I can come up with is from a bizhub 423/363/283/223.
            Part number A1UD 7103 01 Lock Claw /Front, on page 28 of the parts manual.
            give it a look and see what you think.
              • 23008
              Nice idea. I've had some familiarity with this item on the bizhub 423, so I can say with some certainty that it wouldn't work. The handle is shaped differently, and the swivel point for the 423 handle is out at the end of the shaft, not on the other side of the handle.
              The PC-203 handle actually looks pretty close. I'll have to check the graveyard. There may be a cassette base I can take a closer look at. Darn! It appears that the PC-203 handle also swivels from the end. So much for that idea.
              Again thanks for brainstorming with me. =^..^=
              • Shadow
                • Sep 2011
                • 455
                your welcome
                • Hansoon
                  • Sep 2007
                  • 3385
                  One day we all will have 3D-Printers and make our own parts.....
                  Hans
                  • EarthKmTech
                    Step aside, noob
                    • May 2009
                    • 2139
                    red painted screws need to be disturbed to access the transfer section on door, c250, c252, c300, c352, c200, c203, c253, c353 disassembly is utterly forbidden, because its aligned in the factory only.
                    you MUST replace the entire side door, hence why no parts are listed under the transfer assy, including the locking mech.
                    Disobey this advice and it will end up costing a transfer belt too, along with a new door, so just do it properly, and do it once.
                      • 23008
                      I noticed the red painted screws, but alas, there was nothing to do but tear into it. Thanks for the advice. =^..^=
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        the konica minolta gods will frown upon you now, for you have touched the forbidden screws.
                        • NRTech
                          • Apr 2013
                          • 45
                          chuckle :-)
                            • 23008
                            I humbly await the lightening strike to my head. =^..^=
                            • CompyTech
                              Super Tech
                              • Feb 2011
                              • 706
                              I have replaced that door before for that same problem... It's a PITA. If you can find a fix for that pawl, more power to you.
