Konica C6501 DV Unit LIfe...
  • methogod
    • Dec 2008
    • 917
    Have a C6501 that is due for new DV Units (600k), any chance i can let them go once more cycle (200K)?? without issue...
    mostly printing is 12x18, and such, so everything is 2 clicks, high coverage... always hits distance before percentage on the PM/parts.
    Save me a nice piece if change if i can wait another Cycle...
    thoughts...
  • Albonline
    • Sep 2008
    • 1144
    Re: Konica C6501 DV Unit LIfe...
    thoughts...
    have seen these go as high as 2 mill. and have seen them not even make 500k. (in any case they are not going to fall apart simply because they hit end of life count) If the images look good and there is not a lot of spillage from the ends and heavy misting all the way across I'd say run them till they quit working.
    • Gort
      Copier Demon
      • Oct 2011
      • 50
      I agree, I have had some go past 1 million. 600k is a guideline for the estimated life.
      Sorry, I do not have a cat in my avatar.
      • Mick01
        • Nov 2012
        • 362
        I agree with the previous replies, if the units look ok then let them run for another cycle, then check again. 600k is recommended life but most times you should be able to achieve 1 mill +
        • methogod
          • Dec 2008
          • 917
          what do i look for?
          becuase i think the same thing, all four of them are at the end of there 3 cycle...
          no dumping but i have never seen any of my C6501s dump DV, only a bad belt/blade 1 time, and another i forgot to take out the RED screw out of a drum.
          Since we use the DU104 drums i let them go about 120% before changing them but i can see the DV is weak right now at 110%, as some of the darker fills (colors) are not even.
          • Albonline
            • Sep 2008
            • 1144
            when they go bad h cut or erection height becomes excessive causing brushing effect and misting
            • methogod
              • Dec 2008
              • 917
              sorry i get the misting, what does "h cut" or "erection height" mean?
              what do i look for exactly - i know what misting looks like (background).....
              i have more experience with the production 920s.
              thanks, doing the PM today (this weekend), thanks for your help...
