Konica Minolta C350 will not print from Windows 7 machine...
  • Hacky
    • Nov 2012
    • 32
    Hi all,
    I'm having major issues with a C350 and a Windows 7 machine. I simply can not get the mfp to print, or do anything atall from the Windows 7 machine. I've tried installing various drivers to get the machine working, but none of them seem to work.
    I understand there are no current Windows 7 drivers for the C350, and doubt there ever will be, but has anybody else been able to find a solution to allow printing? The machine can not simply just 'not work' because the clients machines are Windows 7.
    As well as the standard C352/350 drivers, I have tried the KM universal print drivers, both PCL and PS, still no luck.
    Quite a frustrating problem, and would be very grateful if anybody has any solutions/suggestions.
    Thanks in advance
  • Mitch Barron
    • Mar 2013
    • 180
    Re: Konica Minolta C350 will not print from Windows 7 machine...
    Grabbed these from our distributor website give them a shot. Worked perfect for me. Hope you get it sorted. Anything else you need give me a shout. Oct.21/2012
    • Hacky
      • Nov 2012
      • 32
      Thanks for the response, I just tried to use the above and had the same problem.
      The drivers install without any issues, but when it comes to printing a test page, or any document for that matter, nothing happens..
      • CompyTech
        Super Tech
        • Feb 2011
        • 706
        Are you getting an error message on the copier or PC? Have you tried to print directly with a laptop and x cable?
        Usually when I can't find win7 drivers the vista ones work ok too.
        • Mitch Barron
          • Mar 2013
          • 180
          Yeah i would try with another source computer like Compytech said. Trial and error. I have never had this problem before.
          • Albonline
            • Sep 2008
            • 1144
            Originally posted by HDSB
            Try configuring the port for LPR instead of Raw? We have had a few Konicas and this worked.
            What port number are you sending it to?
            • MFPTech
              • 486
              Originally posted by Hacky
              Hi all,
              Thanks in advance
              Try XPS driver
              • drimouxlas
                • Oct 2012
                • 27
                Good morning you should go to port parameters and disable SNMP try it
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  you must use raw, port 9100.
                  its under port configuration.
                  win7 seems to default to LPR for some stupid reason.
                  also, if the machine is running the primitive version of account track that's on c350's your not going to get away with an incorrect driver either.
                  • knightfall
                    • Jul 2006
                    • 633
                    silly questions but can you ping the ip address of the copier? also did you use standard tcpip when setting up the port?
                    Get your facts first, and then you can distort them as much as you please.
