C450 BOLD BLACK TEXT is FUZZY
  • PCSControls
    • Sep 2010
    • 9
    BOLD black is fuzzy when I print something. This seems to be only when printing just black not other colors. This started after I replaced all of the IU's. I did the gradation setup after replacement and the colors all look fine. Any ideas on what else to look at or adjust? Thanks
  • Albonline
    • Sep 2008
    • 1153
    Re: C450 BOLD BLACK TEXT is FUZZY
    Try cleaning the led array with alcohol.
    • MFPTech
      • 486
      Does it do the same when copying?
      • darry1322
        • Oct 2010
        • 817
        I've removed all image units, waste toner box and belt to clean led write heads with a damp cloth from the waste box end of the copier. Sometimes they just need a better cleaning than the wand can give.
        • Dickie
          • Nov 2011
          • 190
          I've seen this a few times on individual colours.
          The print heads are lifted up and down on springs when the lever is opened to allow the I/U to be removed.
          Sometimes the springs just do not seem to push the head back to the correct position when the lever is closed back up.
          Just remove the I/U and push the head side to side and down a few times, then refit the I/U. I found this cures it every time I've had this problem
          • PCSControls
            • Sep 2010
            • 9
            Dickie, thanks for the tip, that seems to have fixed up this problem.
            • Dickie
              • Nov 2011
              • 190
              No problem, glad to help
