Konica Bizhub C-353
  • acsolutions
    • Jun 2010
    • 519
    [CQ] Konica Bizhub C-353
    Hello tech's, The c-353 I'm working on is back grounding on the first page and first 4 inches of the leading edge only ( sample attached), after that it runs fine for that job. What it looks like to me is loosing developer bias. I pulled out the transfer unit and all the I/U"s and cleaned cavity well and pulled the cleaning unit from the transfer assembly and vacuumed the cleaning section for stray developer. I also replaced the black I/U, same problem. When the CQ problem happens the image under the background looks ok. any suggestions would be greatly appreciated. Thanks
    sample 5.pdf
  • acsolutions
    • Jun 2010
    • 519
    Re: Konica Bizhub C-353
    and it is also pulling developer! grainy affected area!
    • B0265
      • Jan 2007
      • 718
      Try changing the printer control board.
      • acsolutions
        • Jun 2010
        • 519
        Why the print contol board?
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Reset the machine by cycling main power & do a gradiation adjust. Then Start with cleaning the laser.......if it's still the same after cleaning it.......replace the mfp board(sdram issue on mfp board-- on Mossel & Thames series). Apparently a problem with ICP5 can also cause issues like this.Konica ICP List.pdf
          • acsolutions
            • Jun 2010
            • 519
            Originally posted by blazebusiness
            Reset the machine by cycling main power & do a gradiation adjust. Then Start with cleaning the laser.......if it's still the same after cleaning it.......replace the mfp board(sdram issue on mfp board-- on Mossel & Thames series). Apparently a problem with ICP5 can also cause issues like this.[ATTACH]21082[/ATTACH]
            Yes, I cleaned the laser slit glasses and performed gradiation adjustments. I will take a look at the main board(MFP) Thanks
            • acsolutions
              • Jun 2010
              • 519
              Looks like that ICP 5 on the print controller is bad just like the diagram you sent read!
              • B0265
                • Jan 2007
                • 718
                We had this on a C253.
                • acsolutions
                  • Jun 2010
                  • 519
                  Blaze, wins a home entertainment center!!! Yeah, the icp5 was open and I replace the print controller. all is well!! Thanks guys
                  • acsolutions
                    • Jun 2010
                    • 519
                    Thanks for that ICP list, very helpful!
                    • Hansoon
                      • Sep 2007
                      • 3349
                      Great solution, thanks for sharing.
                      Only question remains: Why did the ICP blow?
                      Hans
                      “ Sent from my Intel 80286 using MS-DOS 2.0
                      https://www.copytechnet.com/images/smilies/biggrin.png
                      • blazebusiness
                        • 1250
                        Glad I could help......looking forward to that home entertainment center LOL.......
                        • mailderrick
                          • Mar 2010
                          • 131
                          Hey i found this thread thankfully. i went up there and long story short i ended up having to change out icp5 on the print control board. Amazing! i don't know how you guys figured it out but it worked. It would always do a developer background at power up on the first page first few inches only. It would work great the rest of the day(unless you powered off the machine) until the next power up. It was driving me and them crazy but it is all better and life is good!!!
                          Thank you again!
                          Derrick
