Jam code j-7550 C8000
  • sasa12u
    • Nov 2011
    • 39
    Hi all,
    any idea for this jam code,from the services manual is locate jam at RU 508 .any idea to solve this problem.
  • Konicoz
    • Jun 2013
    • 62
    Re: Jam code j-7550 C8000
    Extract from trouble shooting guide
    Temporary countermeasure: Paint edges of sensor light axishole by black marker and change the direction of the fan. (See attacheddocument)
    Permanentcountermeasure: The clearance hole for sensor light axiswill be enlarged. Change the installation direction of the fan. Change therelay wirings.
    Serial number cut in:
    [RU-509]
    A2A2W01000103
    A2A2W11000497
    A2A2WY1000709
    [RU-508]
    A1TTW01000056
    A1TTW11000305
    A1TTWY1000312
    * Please apply temporary countermeasure ifJ-7550 occurs before applying the permanent countermeasure.
    Hey what ya doing? - just screwing around.
    • sasa12u
      • Nov 2011
      • 39
      Hi konicoz,
      i try this method before unfortunately,the jam code still appear.actually my customer use A3-80gms to print their jobs.any other solution.thanks
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        Originally posted by sasa12u
        Hi konicoz,
        From Tech bulletins: RU-508 /HM-1021. J-7551 or J-7552 occurs if the guide plate under the entrance is not fully locked2. Water leakage of HM-101/1023. J-7550 occurs due to misdetection of the entrance sensor. OR------------------------Description
        J-7550. When a copy/print cycle is started, the paper will jam as it enters the external fuser unit.
        Solution
        CAUSE: Sensor PS13 (paper entrance to EF-101) is knocked out of place and may have shorted 5V DCto metal guide plate. ICP15 isOPEN on EFCB.
        Note : There is no indication on themain body that could indicate any fault with the external fusing unit (EF-101). The jam codereferences the
        RU-508Entrance sensor (PS1)not turning ON within a specified period of time.Usually when ICP15 is OPEN, C-5024 error code is indicated.
        SOLUTION: Reposition PS13 and replace EFCB (p/n A1RJ H010 03).
