Ethernet Power Adaptors
  • Taminol
    • 171
    Hi guys,
    Has anyone ever used any of these type of adaptors before?
    They're supposed to create a network infrastructure over the mains power system.
    Something like this
    TP-Link AV200+ Multi-Streaming Powerline Starter Kit with AC Pass Through : 200Mbps Powerline Adaptors and Kits : Maplin Electronics
    We're thinking about this for an installation without network access in the 'copier room'.
    Cat5e cabling isn't really an option, due to the nature of the building.
    It's a KM Bizhub C224e and simply needs to be able to print and scan.
    May need a bit of Account Track and Secure Print in time, but if the first bit works, the rest should follow suit?
    I can't see it being a problem, but wanted to ask my friends and fellow Techs what they thought.
    Thoughts or views anyone??
    Tam
  • kahdgar
    Re: Ethernet Power Adaptors
    I use these in my house and they are amazing. I couldn't tell a difference between cat5 cable and these power adapters. I dont use them for copy machines though so idk if you will run into any problems.
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      I've not tried it but I remember someone mentioning it on here but they've used the network adapters for gaming systems. I've got one on my xbox that works great when I stream media across the network from my laptop to my xbox.
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • tech51
        • 846
        As long as its all on the same ring main circuit it should be ok. I use these at home as well and the link is far more reliable than wireless. I stream video over mine with no problem so it should cope with printing and scanning.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          I have used them in the home environment and have also setup a konica minolta machine in the field using them too.
          No issues.
          • Phrag
            • Oct 2012
            • 417
            I've heard of these, but never used them. I was a bit sceptical about it using the mains power to transmit data. Wouldn't it receive inference from the 240V circuit, or does it have to be on its own, isolated, unpowered circuit?
            • RRodgers
              • Jun 2009
              • 1947
              We've used a Buffalo wireless bridge with great success.
              • Hansoon
                • Sep 2007
                • 3347
                I have two customers both with Bizhub 350 B&W's using it. I was extremely sceptical in the beginning but they insisted. This is now going for at least 4 years without any problem. Scanning and printing in B&W without problems and/or noticeable dragging.
                Both adaptors however must be at the same phase otherwise a phase coupler must be installed in the distribution panel box.
                Hans
                “ Sent from my Intel 80286 using MS-DOS 2.0
                https://www.copytechnet.com/images/smilies/biggrin.png
                • Taminol
                  • 171
                  Thanks everyone for your feedback.
                  I going to check out those xbox gaming adaptors, as I can see they pretty much turn an ethernet device in to a wireless device.
                  But failing that, will purchase a pair of 'ethernet plugs' at the weekend
                  Installation is next week, so I'll post on how it goes.....
                  Thanks again.
                  Tam
                  • paulrid
                    • Nov 2011
                    • 206
                    I use them at home and at customers, work really well.
                    Paul.
                    • tech51
                      • 846
                      They dont use mains power to transmit the data. They transmit data using the mains wiring and use filtering to remove any electrical noise. They have to be on a powered circuit because they are powered by the mains. I was as sceptical like yourself but having used them at home I would have no problem with using them at a customers...
                      • Phrag
                        • Oct 2012
                        • 417
                        Very interesting. I'll be forced to use wireless shortly, instead of a light pink ethernet cable. I might have to look at using these. Must be pretty effective then, hearing you guys go on about them. I imagine using some thicker, higher quality copper would allow for a greater bandwidth.
                          • 22930
                          Just out of curiosity, what does the color of the cable have to do with anything? =^..^=
                          • Phrag
                            • Oct 2012
                            • 417
                            Did I say pink? I meant lightish red.
                            No, but in all seriousness, the colour has nothing to do with it. But it matches my pink iPod. I just wanted to be different. Everyone else uses blue. How dull is that? =)
                            • Hansoon
                              • Sep 2007
                              • 3347
                              If talking about the water supply I can imagine that a fatter pipe some times is of advantage but "thicker, higher quality copper" would most likely not have an influence on the performance of a TCP/IP network.
                              Hans
