CF023
MsgQue OverFlow
An exceptional instance occurred due to the unexpected Parameter in the System F/W.
Relevant Electrical Components, Units, and Options - MFP Control Board (PWB-MFP)
Try to reset it. If it is still showing up, you should try a new firmware version. If it is not working with a new firmware, you should check all the connection to the MFP Control Board. In the worst case scenario, you should change the board. I hope a reset will do the job
CF023
MsgQue OverFlow
You can reset the machine not only the MFP board. To reset the copier, shut it down from the main power off button, keep the Utility/Counter button pressed and power it on. Keep the Utility/Counter down until the Trouble/Reset button shows up on the touch screen. Press it and power off and on the machine.
