C2801 Or C2804 Bh 500
  • kesserling
    Last week i have a big trouble with the code C2804 WITH A BH500
    I CHANGE THE DEVELOPPER TWO TIME and after 200 or 300 copy the code fall
    Now i find the problem i do 2000 copy and now i don't have this code
  • kesserling
    ERROR
    THE code is not C2804 BUT C2803
    SORRY
    • ni311
      • May 2008
      • 658
      If the problem re-appears, check the TCR sensor (TCRS). If the TCR sensor is ok, check the printer control board (PRCB) and its connections.
      Konica Minolta Error Codes - Explanations and Solutions
      • kesserling
        THANKS
        i have two bh 500 and the same code appears on the both i change the TCR in one copyer the same code appears
        Now i am sure the cause is on this picture number 4 see it
        now i don't have this problem i replace the clear and it s go very good
