BH-C-20, empty prints
  • Hansoon
    • Sep 2007
    • 3389
    BH-C-20, empty prints.
    Customer called me that suddenly the machine produces only blank empty sheets of paper. Copies, prints and internal print outs result in a sheet of paper without the slightest image on it. No error codes.
    My guess is 1st or 2nd transfer but since the machine is located in a far location and I never had this nor heard about such an issue I'd like to know before I go there if of any of you guys had similar experiences. Any ideas please?
    Hans
  • princef18
    • Jul 2011
    • 37
    Re: BH-C-20, empty prints
    Hi,
    There is a lock that keeps the 2nd transfer roller in place. That might be broken. I had a similar case once and it turned out that one of the locks was broken.
    There's also a spring under the 2nd transfer assy. That could have been displaced.
    Hope this is helpful.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      I've had this happen too and it was simply a case of restarting the machine.
      • wseyller
        • Sep 2012
        • 1129
        Had a same issue yesterday but with a C280. The transfer belt was torn up and to the point where it couldn't rotate at all.
        Sent from my Galaxy Nexus using Tapatalk 2
        • Hansoon
          • Sep 2007
          • 3389
          Didn't throw an error code?
          Hans
          • wseyller
            • Sep 2012
            • 1129
            Nope. Copies and internal prints just came out blank.
              • 23009
              Pretty! =^..^=
              • Hansoon
                • Sep 2007
                • 3389
                Re: BH-C-20, empty prints **solved**
                Just restarting the beast cured the problem.
                Thanks for all the input guys.
                Hans
