Setting Powder Help
  • captkirk
    • 39
    Setting Powder Help
    I have left my setting powder at the office. I need to change drums on Konica Minolta c500 pro. Has anyone ever used anything else?
  • Scareit
    You can use Toner
      • 23008
      Only in the last few years have I stopped using toner, and started using the manufacturers setting powder. Sharp was very emphatic about using the Titanium Sterate setting powder on the transfer belts. The reasoning was that other types of setting powder somehow stick to the belt leaving image voids.
      Personally, 99% of the time toner should be fine.
      • ni311
        • May 2008
        • 658
        Toner is just fine, I am using it for years, never got problems with it.
        Konica Minolta Error Codes - Explanations and Solutions
        • captkirk
          • 39
          Thanks I have used toner in the past as well, but did not want to damage new drums. Always nice to have more than one opinion.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            On the color boxes always use Yellow toner. It's the least visable if something goes wrong.
            Mystic Crystal Revelations
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Toner never fails. I quit using setting powder after having to explain the tiny ziplock with white powder while getting searched before going into a prison.
