C364e
  • support@itecgroup.com
    • Apr 2013
    • 16
    C364e
    Hi,
    We seem to have problems updating the F/W of the C364e range machine's.
    We are using USB memory stick, but machine does not boot up in the update screen.
    I have tried numerous "folder structure" ways.
    Do anyone have the correct procedure for me?
    Regards
  • kingarthur
    • 1385
    Re: C364e
    Originally posted by support@itecgroup.com
    Hi,
    Regards
    Are you using the correct USB port, the one hidden behind the metal plate
      • Apr 2013
      • 16
      Re: C364e
      Yes, I am using the service port.
      • Gaffers01
        • May 2011
        • 335
        Re: C364e
        What about trying a different USB stick. I have had this problem with different models of KM machines.
          • Apr 2013
          • 16
          Re: C364e
          Have tried different sticks, and updated a C364 with the same stick after the issues with the C364e. Know that they use different versions.
          • Mitch Barron
            • Mar 2013
            • 180
            Re: C364e
            Have you tried another firmware?/have the right firmware?/Unzipped, zipped? I have also had machines jump service mode for not recognizing the data.....I have the most recent here when you need it. Give me a shout if i can help.
              • Apr 2013
              • 16
              Re: C364e
              I am using this F/W A5C10Y0-F000-G00-18 .
              My question is in what folder struckture mst this be? what must lie in the root of the stick? Maybe Tar.exe or the contend of the cw folder or the contends of A5C10Y0-F000-G00-18?
              • JustManuals
                • Jan 2006
                • 9838
                Re: C364e
                Are you using the firmware imaging toolkit?
                Paul@justmanuals.com
                  • Apr 2013
                  • 16
                  Re: C364e
                  No im just cpoying to the memory stick 2Gig Fat 32 formatted
                  • Mitch Barron
                    • Mar 2013
                    • 180
                    Re: C364e
                    If you have a .zip then you must unzip the file. Then you are presented with a new folder (not zipped) everything in that folder should be then copied into the root of the usb stick. Meaning when you open the USB for the first time you will see lots of data....no folders. Plug the stick into the service port.....turn the machine on and you are good to go. Should work. I just did a 224e yesterday.
                    • Mitch Barron
                      • Mar 2013
                      • 180
                      Re: C364e
                      As per your firmware I have
                      Dated January 17 2013.
                      Let me know if you need it.
                      • Destoned
                        • Jul 2009
                        • 24
                        • Moza
                          • 232
                          Had the same problem yesterday on a C454e but just seems I was a little impatient.
                          All you need to do is extract all files to a compatible usb stick, insert into the service slot underneath the plate swich machine on and wait.......and wait.
                          The machine doesnt look like its doing anything for ages and doesn't even boot properly but eventually you should get the firmware update screen.
                          Just be patient
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            Re: C364e
                            function version 3 firmware is already out for the e series (version 63 onwards) and requires function version 3 drivers to work correctly (when enabled)
                            everything prior to 63 on the e series is buggy as hell and should be avoided - new installs also shouldnt be using function version 2 drivers as they will just need to be installef again later.
                            • speedtek
                              • Apr 2013
                              • 46
                              Re: C364e
                              I have had zero luck updating any 4-series Bizhubs via USB. I have since started using FTP (Internet ISW) and it works great, once you get a hang of it.
