Bizhub C20 faded band on copies/prints
  • cwharrington
    • Jul 2025
    [CQ] Bizhub C20 faded band on copies/prints
    Getting a faded band on copies/prints. Image formation is good on transfer belt however when it is transferd to the page it has a 2" faded band just off of centre running parallel to the feed direction. Only physical thing I see is a white band around the middle of the transfer roller.
  • wseyller
    • Sep 2012
    • 1129
    So is it printing light in the 2 inch area? You say image formation on belt is good. So if the toner is not fully transferring to the paper in the 2 inch area then sounds like the transfer roller does not properly apply charge to the paper. Replace the transfer roller.
    Unless you upload a test print here it is hard for us to give the best advice.
    Sent from my Galaxy Nexus using Tapatalk 2
    • SmellsHot
      Head Tech
      • 512
      Re: Bizhub C20 faded band on copies/prints
      clean print head window
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • Dougtech
        • Apr 2011
        • 113
        I agree - most faded bands are dirty laser window/glass. a tell-tale sign to me is that the faded area has clean sharp edges, not fuzzy like when developer roller gets a faint stripe from some sort of debris by mag roller.
        But if image is great on transfer belt that rules that out. Did you stop image on paper before fuser? How does that look? If band is there I agree that you need new transfer roller.
        • Hansoon
          • Sep 2007
          • 3384
          Often hard to see on the dark surface. My 1st guess would be too the laser window(s).
          Hans
          • cwharrington
            Yes this was my first guess, just wanted to get other opinions to confirm this. Thank you all for your help, will give it a try.
