bizhub 751 Copies Dramatically Lighter than Prints
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [CQ] bizhub 751 Copies Dramatically Lighter than Prints
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • scottybbb
    • Dec 2010
    • 126
    Re: bizhub 751 Copies Dramatically Lighter than Prints
    Have you tried cleaning the optics.
    • MFPs R Now PCs
      • Jul 2011
      • 156
      I guess I should have mentioned that we also have cleaned the Optics, Mirrors and CCD Lens. (oops)
      • ZOOTECH
        Senior member of CRS
        • 3377
        Don't know much about KMs, but is copy mode perhaps in "Toner Save" condition verses print mode in normal?
        • WetPaper
          • 14
          Did you try both off the glass and the adf? Was there a difference?
          There are KM models where you can adjust the ADF density separately from the glass but I can't remember if the 751 is one of those. This would be cheating of course.
          Has the CCD or Image Control Board been ruled out yet?
          • MFPs R Now PCs
            • Jul 2011
            • 156
            Overnight it's now printing really light, even the Machine Management List is Very Light. I cannot seem to find the "Troubleshooting" Section in the Manuals "Field Service" or "Theory of Operation" for Copy/Print Quality Control (i.e. Light Print/Dark Print/Lines/Shaded Background/Dots on Page etc, etc.. like there is for ANY C Series Machine C451/C550/C650) Could someone point me in the right direction for finding these sections in what Manual, please?
            • Zackuth
              • Aug 2009
              • 448
              You mentioned drum/developer change. Have you also done the transfer/seperation wire and cleaning unit changes, charge grid maintenance?
              If at first you don't succeed, redefine success
              • CraigW
                • Dec 2010
                • 417
                If you take the dev unit out and spin by hand using the large white gear .... do ALL of the other gears (in stirring section) spin as they should ??
                If those smaller gears get worn it cannot add toner to dev unit.
                • ZOOTECH
                  • 3377
                  OP said prints ok, just copies are light.
                  • Luther
                    • May 2006
                    • 682
                    Like above said make sure the dv gears are not worn down, also make sure the sensor under the drum is not dirty
                    • MFPs R Now PCs
                      • Jul 2011
                      • 156
                      The sensors underneath the drum are still clean. All of the processes indicated in the Adjustment Section of "Field Service" manual for replacing the drum were performed at the time of replacement.
                      I tore it apart again today and reinspected/cleaned everything, all charging units got cleaned, re-powdered drum and blade too. All gears on the developer are turning properly. Now prints are definitely dark again but everything is shadowed on the trailing edge. I did notice this before starting today but now it's very pronounced. Getting a secondary tech onsite. This WILL be resolved! Ha, ha.
                      As far as original post prints vs copies on too light: It started with only copies but in 1 day before I got on-site myself it now includes anything, even prints...?
                      • CraigW
                        • Dec 2010
                        • 417
                        Also for light a couple of days ago I had a 601 light, and found the spring out of place on the little black cover that closes when you remove the drum carriage. Right near the front.
