Bizhub 223 sqeaks when printing tray 2
  • wseyller
    • Sep 2012
    • 1129
    Copier was installed as new around 9/2012 it currently has less than 30k pages. No optional paper trays installed.
    When printing from tray 2 after a several pages a squeak squeak starts getting louder and louder. It doesn't go away until it sits for a while. I go to print tray 1 perfect then go back to tray 2 squeaking very loud. Squeak seems like it is coming from around the area of the paper feed or some gears in drive. Can't quite pinpoint it.
    I took the tray 2 paper feed unit fully apart. Cleaned and lubricated every part of shaft that has a rotating part except in areas like one-ways and the tray 2 feed clutch. Did not help
    I tore the copier down to the point where I got the main drive out. I check everywhere for proper lubrication. I then pull up the theory manual and I don't think the main drive could be an issue because it would squeak with both trays right? I wanted to pull the hopper/paper drive section but there is no instruction in the manual and I couldn't quite figure it out, and I felt like I had removed way to much already and didn't want to dig myself into a hole.
    From the looks of it the hopper/paper drive section is all running when either tray 1 or 2 is feeding, so it shouldn't be an issue right?
    So it is safe to assume that it is definitely something on the tray 2 paper feed unit. This unit has the tray 2 clutch on it. Can I eliminate the rest of the copier?
    Edit: Or maybe the vertical transport could be possible too. I assume it's clutch only energizes when printing from tray 2
    • 23008
    Re: Bizhub 223 sqeaks when printing tray 2
    Originally posted by wseyller
    ... Edit: Or maybe the vertical transport could be possible too. I assume it's clutch only energizes when printing from tray 2
    Now you're thinking. I would suspect those little idler pulleys inside the vertical path, lower door. =^..^=
    • Hansoon
      • Sep 2007
      • 3385
      They are MEAN!
      Indeed, if squeaking is not being caused by the usual suspects than it is ALWAYS those damn idler rollers.
      Hans
        • 14754
        Originally posted by Hansoon
        They are MEAN!
        Hans
        Idler rollers are the devils playgrounds! lol
        • wseyller
          • Sep 2012
          • 1129
          I do believe it is in the vertical transport now. Wish that popped in my head when I was there. I may never know the conclusion of it . My call was transfered to someone else because I will be gone next week in GA for some fiery training. I appreciate the feedback though.
          Sent from my Galaxy Nexus using Tapatalk 2
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            yep, ive had the problem.
            and it was the white idler rollers already spoke of, on a near new machine.
            lube em up, problem solved.
