konica 7222 fuser jam
  • DOE
    • Mar 2010
    • 258
    have a konica 7222 that jams in fuser. if i run 8.5x11 it jams under the 2 middle fingers in fuser. if i run it r ways it goes through fine. replaced fingers, web and rollers same thing. the customer says it might work fine one day and then jam everytime the next. i suspected moisture in paper was the cause but i opened a new ream of paper and it jammed everytime under middle 2 fingers but when i changed it to r direction it worked fine even though the same 2 fingers that it jams on 11 inch is same ones it uses to peal off the r direction paper. i have stopped twice before and couldnt get it to jam but this time it did every time. any ideas would be apreciated as the customer and myself are getting frustrated. thanks
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Re: konica 7222 fuser jam
    Alot of the time the latches on the fuser break on that model. They are black in color if memory serves me and the end piece breaks of and the fuser doesn't latch snugly when you close it. Might cause that issue.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • CraigW
        • Dec 2010
        • 417
        ^^^ yes, the latches.
        And make the white material on the fuser input plate is in place (more common on older 7020 series)
        • pepper38_cnd
          Field Service Manager
          • Aug 2005
          • 1075
          Check to make sure all the little star wheels mounted on the drum carriage rotate freely if they don't they will cause odd fuser jams any that don't rotate just pull them off it will work fine without them.
          Now into Ip TV KODI Boxes
