Konica 1216 service call reset
  • hekotez
    • Jan 2007
    • 91
    As the title says, we have here a Konica Minolta 1216 that my college serviced, machine is ready to go but the servicing request light is on and he doesnt remember whats the steps in service mode to reset it.
    Can anyone please help out on this?
    Thanks alot for any help in advanced.
  • vj200729
    print mate
    • 81
    press 25 switch on .enter 47 .press start.enter 1 .press start.switch of and on.
    • dogsbody
      • Jun 2007
      • 289
      if i remember rightly,
      47 mode, 51, start for L-detect (after dev change).
      47 mode, 90, start for the PM counter.
      The force will be with you always.
      • hekotez
        • Jan 2007
        • 91
        thank you
        thanks for the input doma873
        • doma873
          • 24
          Is this ment to be funny or just a joke. The above quote is to reset F34 , 35, 36 codes that relate to fuser error. Nothing to do with reseting PM counter.
          Now for an old trick. If you haven't replace the dev and still want to reset the pm count go into 25 mode and set p33 p34 p35 to all 0. Then turn machine off then back on. If you do 47mode 90 you will have to perform L detect ofter that 47mode 51 otherwise you get error f26 from memory.
          Be a long thme since i have worked on these models but i remember servicing thousands of them years ago
          • fareeduddin ahmed
            • Jun 2008
            • 11
            1 ) hold 4 and 7 key together and switch on machine then enter key 9 and 0 then press print this will rest your service call indication
            switch off machine
            2) hold 2 and 5 key together and switch on machine then enter key
            5 and 1 then press print this will callibrate developer one to two
            munties machine stops when over switch it off and on will solve
            your problem
            3) ** its all this not adviceable without changing of pm kit which is due
            be standard to fallow as recomonded by manufacturer
            • konikilla
              • Nov 2008
              • 43
              In service mode
              set P27 to 90
              and then
              set P28 to 09
              This doesn't reset the PM counter but changes the PM counter to it's maximum setting. This way you'll get the service light off without running the risk of having to change the Developer.
              • minolta35
                Trusted tech
                • Apr 2005
                • 87
                What does it mean P25 and P26
                I've got a 1216 display P25 and P26.I don't know its mean and how it fix or reset it?
                • JustManuals
                  • Jan 2006
                  • 9838
                  This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
                  from The Internet's largest collection of manuals
                  Paul@justmanuals.com
                  • Mikey
                    • Sep 2009
                    • 54
                    That means you have problem with toner density. Check the TDS. To reset go to 47-51.
                    • Naveed Shahid
                      • May 2008
                      • 162
                      konica
                      hello
                      try to 47-51
