Bizhub PRESS C6000 error codes
  • unlimitedbt
    • Mar 2009
    • 80
    Guys we have just picked this machine from Leasing company, it has a few errors..
    C5304 - this is some kind of FAN error but I don't have the service manual for it yet, tried to use C6501 manual but it goes as far as C5403, no 5304. Anyone proficient on this model can point mi in the right direction please?
    Also when "Server" button is pushed it displays error "d0e2" anyone knows what it means please? it is a IFY Fiery 80... I can't change the IP Number, I mean I can change it but can't save it....
    Thanks in advance.
  • mikeena
    Branch Technical Manager
    • Mar 2007
    • 220
    Re: Bizhub PRESS C6000 error codes
    its the main body hdd cooling fan i believe rotate it manually by hand check connection and if that dont work replace cooling fan 1 and 2 second part is it showing 02 on the fiery if so install system software back on the fiery again as it has corrupted has happened two me once if the fiery does not shut down correctly it corrupts
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • unlimitedbt
        • Mar 2009
        • 80
        Mke hi, let me ask you please...
        Machine came with everything - manuals, service records but no Fiery CD, Any chance I can borrow / buy or any way get one from you please?
        Also there is a block in the back with 6 HDDs, what does it do?
        Thank you.
        • unlimitedbt
          • Mar 2009
          • 80
          Mike hi, Thanks a million to your advice, I have solved the problem - turn out to be that a block with 6 HDD's in the back was disconnected, all HDD's did not have power, power to 2 fans was disconnected as well. Once everything was connected, machine went straight to ready...
          Thanks again.
          • timk
            Can some help me. I'm getting a C3501 error code on a Bizhub Press C6000 and I can't clear the Call Service screen.
            • laitang
              • Nov 2012
              • 627
              C3501: Estimated abnormal parts:
              • Fusing unit
              • Printer control board (PRCB)
              • AC drive board (ACDB)
              • Fusing heater lamp /1 (L2)
              • Fusing heater lamp /2 (L3)
              • Fusing heater lamp /3 (L4)
              • Temperature sensor /1 (TH1)
              WARNING
              • After replacing the defective parts, be sure to set the DIPSW 3-1 to 0. If DIPSW3-1 is set to 0 before defective parts are fixed, it may cause fire.
              Solution
              1. Check the connection between the rear side connector of the fusing unit and the main body side connector, and repair it if any abnormality.
              2. Check the connector connection and the wiring between PRCB and the temperature sensor, and repair it if any abnormality.
              3. Check the connector connection and the wiring between ACDB and the fusing heater lamp, and repair it if any abnormality. (Wiring diagram: Main body (1/3): 3-E)
              4. Check the installation condition of the fusing heater lamp and ON/OFF with I/O, and repair/replace it if any abnormality. (Wiring diagram: Main body (1/3): 3-D)
              5. Check the installation condition of TH1 and temperature of I/O, and adjust/replace it if any abnormality. (Wiring diagram: Main body (1/3): 3-F)
              6. Replace TH1.
              7. ReplaceL2, L3 and L4.
              8. Replace ACDB.
              9. Replace PRCB.
              • timk
                Thanks for your help I'll try these steps.
                Originally posted by laitang
                C3501: Estimated abnormal parts:WARNING
                Solution
                6. Replace TH1.
                8. Replace ACDB.
                9. Replace PRCB.
                • Kenny
                  • Jun 2009
                  • 530
                  Does anyone know the part number for the Hdd cooling fan can't seem to find it ?
                  thanks
                  • Synthohol
                    Certified Konica Expert
                    • 5868
                    here ya go.
                    A1RFM15100
