bizhub 250 can not perform f-8
    • 14520
    #16
    Re: bizhub 250 can not perform f-8
    Sounds like the MFBS board. Replace it from a scrap machine. Don't forget to swap the NVRam.
    • eg101
      • Jan 2005
      • 131
      #17
      Originally posted by DOE
      Replaced developer unit, still get the same code. Ordered the developer from Percission they sent me the Di Could it be a different amount of developer?
      Yes, t
      the DI 2010 series uses a smaller package of
      developer than the Biz 250 series.
      • Hansoon
        • Sep 2007
        • 3374
        #18
        Yes, t
        Not only that, but it is also a very different incompatible type of developer.
        Hans
        • Blizzoo
          • Aug 2013
          • 607
          #19
          Hi there,
          My first post and hope that helps.
          The C2557 could appear when the Imaging Unit have a poor cupling with de drive gear/broken gears and the develper is not mixed well then the ATDC sensor fails.
          • copierguru
            • Jul 2011
            • 27
            #20
            Had this issue once. Drive me nuts for almost 2 days. Check the toner supply solenoid. They stuck sometimes and this will cause the c2557 and 255c codes. Also you will probably need to replace your dv again.
            • DOE
              • Mar 2010
              • 258
              #21
              replaced the gear pack that has toner solenoid it and now i am getting a c2211 code. sounds like a problem with gear that drives it. humming noise and gears do not turn. was getting a c2557 but after trying it a couple times its changes to a c2211. replaces toner solenoid because you didnt hear any toner adding during f-8 so it made sense. could the line that is on a spring for side door get tangled in that area as it does run by gears that drive dev. unit. doesnt seam to be caught on anything but i did have it off to get to toner solenoid.
                • 14520
                #22
                Toner does not add during an F-8. It is reading new dev with the proper T/C ratio.
                C-2211 is IU motor failure to turn. Check the motor connector, and check to see if the dev unit is binding.
                Hope this helps.
