bizhub 250 can not perform f-8
  • DOE
    • Mar 2010
    • 258
    hi i have a bizhub 250 that i first reset drum and developer count, replaced drum blade and developer then tried to do f-8 but when i got to screen with FUNCTION button it just beeps when you press it. same with button below it but rest of them work fine. copier still worked for a couple days then the 2557 code was back. any ideas why the function button wont let me into the f-8 screen. thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: bizhub 250 can not perform f-8
    Paul@justmanuals.com
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      This is what I do and it works every time.
      1.Fully power off machine, open right side door.
      2.Power on with door open. Go in tech rep mode. Clear drum and dv life counters.
      3.Close door, back out of counter section, then go to F-8 mode and hit the start key(button should turn green by that point)..
      Hope this helps.
      Good luck
      • Hansoon
        • Sep 2007
        • 3389
        .....and also don't forget to switch the machine off with the fat main switch at the rear of the machine instead of the control panel switch after clearing of all the counters.
        Check if all counters are set at "0" otherwise repeat the procedure.
        Hans
        • wseyller
          • Sep 2012
          • 1129
          Yeah just because you clear the counters doesn't mean they are really cleared. I will turn off main switch and turn back on to see if they are still clear to make sure.
          Sent from my Galaxy Nexus using Tapatalk 2
          • kingarthur
            • 1367
            This is going to sound really stupid, but I have had some m/c's do that if the doc feed wasn't in the down position.....got no idea why
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              yep. some machines find any excuse not to cooperate.
              I've had this too - and i usually build the imaging unit on top of the scanner with the document feeder open, only some machines really don't like it, others don't care. Must be a firmware thing.
              • DOE
                • Mar 2010
                • 258
                I am now getting a C255C Code any clues ? I cleaned the sensor in developer unit.
                  • 14791
                  Try a new dev unit or replace the ATDC sensor.
                  • DOE
                    • Mar 2010
                    • 258
                    Replaced developer unit, still get the same code. Ordered the developer from Percission they sent me the Di Could it be a different amount of developer?
                    • CompyTech
                      Super Tech
                      • Feb 2011
                      • 706
                      Could be bad DV.. I've never worked on the Di so I don't know if they're the same.. I know some of the parts will fit it. The code says replace ATDC sensor, run F8. But you'll probably have to load new DV into the unit. Worst case, you got a bad board.
                      • krm
                        • Aug 2009
                        • 233
                        The Di series developer will not work with the Bh250 machine. I put the Di 2010 developer in a machine once by accident/brain fart and it coded out. You must use the dv311 developer. Just had this code the other day because the Pc counter did not reset for some reason. Use the correct developer and run that reset procedure outlined above and you should be good. The f-8 is flukey with this machine.
                        • DOE
                          • Mar 2010
                          • 258
                          it did turn out to be konica dv310 developer i used which is rightfor the 250. i replaced drum, blade, dev. then tried a different dev. unit and still get c2557 or c255c. i was able to get into f-8 finally by leaving side door open while i cleared the counts. i have double checked the counters and they say 0. usually when i mix dev in these machines you hear clicking noises and such for a while but not this one. runs smooth from beginning. tried even adding some more dev. to unit in case not enough still same results. the copier had a c2557 code when i first went
                          • Hansoon
                            • Sep 2007
                            • 3389
                            Hans
                            • Lynn56
                              TECH
                              • Jul 2012
                              • 21
                              Go in to service mode and set the ATDC sensor gain up about 20 from what it is now.
