Bizhub 600 Always warming Up
  • Wasfil
    • May 2008
    • 20
    Bz600, after I do Copy and hushed 1minute or more, lather than The machine canot use, at screen come up this Message "Please wait Warming up the machine" Before that always eror code C2803 & 2804, My counter is 300.000
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    On other models of Konica Minolta, when he machine keeps warming up, it is looking for toner to complete the job. If the bottle has toner, and conditions are humid, you may have to clean out the hopper under the bottle holder.The toner could stick together around the auger, not allowing it to feed into the DV box.
    • Wasfil
      • May 2008
      • 20
      Thanks, but that to long time and canot be use until I tur OF and Turn On again. And That problem always happened every day.
      • ck1
        • 485
        just follow fixthecopier said, check the thing .
        • Downunder
          • Aug 2007
          • 174
          At 300,000 hope you have replaced drum, starter, blade etc. Best to do this at correct time, 250,000, or problems will come your way.
          • RockETop
            Curmudgeon at large
            • Apr 2007
            • 171
            I have a machine with over 1M copies that just started this today. I'll let you know what happens. RET
            Edit: after a little research, I vote TCSB. I had already cleaned out the process unit. I'll hose out the toner supply unit tomorrow first....cheaper!
            • doma873
              • 24
              I would do the above first. I have also had a faulty Dmax sensor cause this problem also. Make sure the sensor is very clean. If you check the service code counter you may see a few dmax errors listed..
              • RockETop
                Curmudgeon at large
                • Apr 2007
                • 171
                TCSB! Went right to work.
                Run drum peculiarity. you may get errors.
                • Wasfil
                  • May 2008
                  • 20
                  PC Drum is be Replaced
                  PC Drum, Starter tobe replace before, but the problem has be come after amoment (1minute) I do copy once in the screen "Warming Up Ready to Scan" I can do Scan, but the result print not going out.
                  I have do : Drum Peculiarity - Auto MAx. Density Adj the result is Ok, then Auto gamma Adjst. (1dot) and (2dot) the result is Error 1, in the book that mean TCSB dirt,
                  In other machine i have change/replace with New TCSB the problem is lose. (Ihave 2 machine with same problem)
                  Thanks alot for All guys.....
                  • redhotrob
                    • 69
                    It may sound kind of strange, but I had one of these machines that would go to warm up and not come out unless the power was reset. I checked everything and all seemed ok. With nothing left to do, I flashed the machine. It already had the latest firmware, but I did this anyway. It's been months now, and the problem has not came back.
                    • pepper38_cnd
                      Field Service Manager
                      • Aug 2005
                      • 1075
                      Could be a bad front door interlock switch, they can cause weird problems.
                      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                      Now into Ip TV KODI Boxes
                      • d7guitar
                        • Jan 2007
                        • 54
                        Contact tech support. They know of this problem and have step by step things to check. Everyone else here has offered great advice and is sending you on the right path for what to check. Ultimately if all other fixes don't work you may have to follow the TAD under solutions for this model that walks you through resetting the machines firmware to the base level and then steps you through each phase of firmware revisions to bring it current. We had one doing this exact thing you described that required a complete firmware rewrite and has been fine since. Check "Solutions" for the TAD on mykonicaminolta.com
                        After all is said and done, More is said than done.
                        • Juggy
                          Technical Support
                          • Sep 2007
                          • 101
                          you will get this message warming up once you find that the Drum unit is heavily contaminated and the dmax sensor is not reading the correct value .You need to clean the drum unit throughly and then check the drum area above the Dmax sensor if it is wornout compared to rest of the area, then replace the drum. Next check that your bias to the DV tank is in proper contact with the DV roller and correct the problem This will avoid frequent contamination of the Drum unit and your Problem will be set.
                          • Christan
                            • 37
                            you should try to replace the imaging processing card it should be defaulty. Check with you department there is a modification kit (from Japan) for the fault.
                            • Wasfil
                              • May 2008
                              • 20
                              Change TCSB and get finish
                              I change TCSB (Toner Control Sensor Board) in Developing unit, and my trouble finish. Thanks all guys
