paper accordion
  • JonD
    • Jul 2025
    [Misc] paper accordion
    Working on a C352, I'm getting an accordion look on the paper on the #2,3,4 trays. It's about 5" down does 4 accordions then 4" good then 2 more. It does not do it on tray 1 or with the bypass.
  • JustManuals
    • Jan 2006
    • 9838
    Re: paper accordion
    Paul@justmanuals.com
      • 23008
      Re: paper accordion
      jam codes?
      • wseyller
        • Sep 2012
        • 1129
        Sounds like something in the vertical transport area near tray 1 and 2.
        What are the paper sizes and types in all your trays.
        Sent from my Galaxy Nexus using Tapatalk 2
        • JonD
          Re: paper accordion
          No Jam Codes,
          paper size tray 2 8 1/2 x 11, tray 3 & 4 11 x 17,
          • JR2ALTA
            • Feb 2010
            • 2033
            Loop timing?
              • 14725
              Re: paper accordion
              The only thing all three of those trays have in common is the set of transport rollers attached to the second tray feed assembly. That is where I would start.
              • wseyller
                • Sep 2012
                • 1129
                Try setting all trays up with the same paper. Make sure paper type settings are all identical and then test all trays again. Ive been fooled before into thinking an issue was limited to a certain tray when the issue was for example a fuser unit.
