The stuff about being careful with developer is crap. I know this is what they say at KM, but we are ALWAYS careful about this. We use the mylar covers included with the drum and are very careful when adding developer, and we still get this problem over and over. There is something else going on.
Bizhub 250/350 eating drums
Some observations I made for another panel some time ago. Perhaps of any use for you though slightly out of context since this was a very long thread overthere:
.......the "nub" on the transferroller is sliding on the drumsurface. Its doing that since the days of the Di-250/350 series and was never causing problems. Old machines with transferrollers over 300K even have the nub being "dug" out by the drums without new drums suffering. The nub is there to keep the distance drum-transferguide constant.
Beside the nub is a small circular disc like roller with a very fine edge. A mark of this edge can be found on the drumsurface but until now never damaged the drum. This disc roller (or collar) keeps the distance transferroller-drum constant.
The distance drum-mag roller however is regulated (or kept) by another disc like roller or collar as Minolta calls them. This roller is sitting on the end shaft of the mag roller and runs also on the drum surface. If worn it can cause drum jitter (most of the larger Minolta's) or in case of the smaller digitals, Di-152/183/250/350/200/251/351 and Bizhubs 200/250/350 will cause ripping of the mylar at the end of the mag roller. Strangely enough almost exclusively the rear one, the driven side, never the front one. The momentum from the gears may be the reason this happens only at the rear of the unit.
However, what seems to happen is that the hole in the collar wears out by the time and becomes larger and at the same time the circumference of the collar wears off too. This wear in total allows the mag roller to come nearer to the drum surface with the mylar inbetween. Eventually the surface of the drum will grab the mylar and rip it off in the direction of the drum rotation. That's the beginning of the end. Re-attaching the mylar with tape doesn't work. The distance between collar-mylar-drumsurface and the strain working on the mylar seems too strong to keep it in place.
The only solution is replacing the collars or at least flip their place from front to rear.
It seems that the new toner/developer of the Bizhub series is more abrasive and that's probably why the Bizhub's are obviously having more often problems than the older Minolta digitals though this very same construction is in use since many years.
The abrasiveness of the toner/developer might explain why Minolta wants the collars being covered when doing the developer change. Hence the mylar strips supplied with a new drumunit to cover the collars avoiding toner or developer particles coming near the collars.
As I mentioned before do I take out the mag roller anyway for cleaning the developer unit and this gives me the opportunity to clean everything well, collars and the shafts, and also allows me to change the collars from front to rear of the mag roller. Measuring the hole and circumference of the collars with a micrometer show a significant difference between of new and old one and also the collar running in front and rear.
and:
A) The drum is fixed and steady in its position by the two metal pins molded in the plastic side covers who in turn are fixed to the developer unit base. Later units have unfortunately a plastic pin which breaks easily.
B) The nubs on the transferroller bushings ride on the drum surface and are there to keep the distance of the spring loaded movable guide of the transferroller constant to the fixed drum.
C) The thin sharp edged collars sitting beside the transferroller bushings ride on the drum surface and are there to keep the distance of the spring loaded movable transferroller itself constant to the fixed drum.
D) The collars sitting on the end of the mag roller ride on the drum surface and are there to keep the distance of the spring loaded movable mag roller constant to the fixed drum.
H) Between the surface of the fixed drum and the surface of the spring loaded movable mag roller are two mylar seals (or guides). The seals are fixed to the base of the developing unit in the cavity under the mag roller. The seals are than led from under over the surface of the mag roller and are attached to the doctor blade with another adhesive piece of seal.
I) The distance drum surface to the mag roller surface is critical not only for the copy quality but also for providing enough space for both seals.
The distance drum surface to the mag roller is determined only by the size of the collars at both mag roller shafts. This distance decreases, especially that of the rear collar, because of excessive wear (probably caused by abrasive toner/developer particles). At a certain point the collar(s) are weared down so much that the gap between the drum and mag roller is not sufficient to keep the seal from being touched by the turning drum. When the drum surface grabs the seal it will be ripped off in the direction the drum turns, in this case downwards.
and:
We manufacture now ourselves collars with an integrated bearing to avoid early wear.
This is a preliminary version, I think to reduce the outside diameter of the ball bearing to 10mm instead of 13mm to have more plastic "meat" around it to avoid cracking of the plastic when getting old.
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
You are correct. The last few I changed were because the small piece of mylar that is on each end of the mag roller, tucked up under the cover. This strip is coming out from under the cover, on the right side, and bunching up and digging into the drum, pealing the finish off.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
Yeah, I know it's CRAP since I'm the one who initially started a ticket on this with KM shortly after the BH250/350 series came out. KM came to the conclusion that we were making a mess of things when that is absolutely not the case. Something changed between the 3510 to bh350 series since we NEVER had a single failure of ds collars on 2010-3510 series machines. We even had a developer unit last over 600k which is impossible with the bh350 series. We've tried everything we can think of- removing the stupid sponge spacer, trimming off the mylar that goes the full length of the doctor blade, moving the thin white ptfe washer that comes installed on the front side of mag roller near the ds collar to the inside between the seal and frame. Nothing has worked. What we really need is to have a source for ball bearing ds collars that are of correct diameter as shown in the above post. I bet the developer units will go to 400k like they are supposed to with ball bearing ds collars!
So, where can we buy these collars Hansoon?Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.Comment
nospam@rex-technika.com
HansLast edited by Hansoon; 12-15-2009, 06:17 PM.“Sent from my Intel 80286 using MS-DOS 2.0”
The problem is the ds collars particularly the rear one get worn and the dev is rubbing on drum we have fixed this prob by replacing dev unit every 3 drums instead of every 4 as per manufacturer guidelinesComment
Shutting off the "PC drum message"
On the bizhub 200,250,350,222,282,362's I've been shutting of the "please change pc drum message" to avoid having to replace these as much as possible. I've had several units run close to 300% But when I do replace the parts, i just replace a new dev unit as well as the drum and developer. This has been working well for me, since i'm saving money by not having to replace the drum and developer at 100%
Very seldom do they crap out before the 100%
To shut off the message, you just need to change DIPSW 418, bit 3 to a 0
Happy Holidays to all!!Everyone has the right to be stupid. Some people just abuse this privelage more than others
We have a problem with a Biz 250 eating drums, it has taken out 3 in the last month, the last time a new dv unit was fitted. Where the drum is worn lines up exactly with the 2 white plastic protrusions on the transfer roller. Was thinking of reducing the pressure on the springs behind the transfer unit assy. Any thoughts on this anyone .CheersTip for the day; Treat every problem as your dog would.....If you cant eat it or f*ck it....then p*ss on it & walk away...Comment
