Konica Minolta C253 Printieng Issue
  • junidexy
    • Sep 2013
    • 32
    I have a issue in the printing Konica Minolta 253, all my other A3 prints are good, when I print through the Cyan color print, I am getting repeat shadow in the print, what might be the problem, any one please help me,
    I attached the image also here
  • suomi
    • Oct 2008
    • 152
    Re: Konica Minolta C253 Printieng Issue
    Cyan IU
    • junidexy
      • Sep 2013
      • 32
      I change IU and Transfer belt also, still same issue , I clean the laser unit also and change at last change I change the laser unit also , still the same problem
      • Zeldaman
        • Mar 2011
        • 946
        Hi there!
        Check the high-voltage-contacts & the fuser-unit.
        Greetings...
        • junidexy
          • Sep 2013
          • 32
          Still has the same problem, no change
            • 22999
            I'm fairly sure it's one of the imaging units, but it's unclear whether it's the cyan unit. What you'll need to do is make some heavy fill copies on single color mode, i.e. cyan, magenta, yellow, black. The source of your problem will become clear. =^..^=
            • Hansoon
              • Sep 2007
              • 3374
              Try to download and print this pdf file. It makes diagnosing the fill of the separate colors more easy.
              Herzlich Willkommen in unserem Download Bereich! - Support - Toner Empty Check
              Hans
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                Paul@justmanuals.com
