Konica Minolta C350
  • copyman
    Owner / Technician
    • Sep 2005
    • 4750
    Konica Minolta C350
    Is there any way to get a C350 to print and scan with Win 8 computers? It does not have the Fiery just the standard controller.
    My IT person said standard controller is PCL 5 and win 8 don't support it.
    Any ideas greatly appreciated.
    Thank you
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Konica Minolta C350
    Konica stopped after Vista.
    Should print through a shared driver tho, no?
    • infoteknerd
      Thank you
      I have the same issue and question. This printer is working to well to get rid of at this point.
      • Discountcopiers
        • Jun 2011
        • 52
        may be time to upgrade . I have had many calls for sofware conflicts with older konica s using windows 7-8. My sales person knows about this head
        each!
        • JustManuals
          • Jan 2006
          • 9838
          You need new Frimware to support this. I have it but it isn't free. Email me at paul@justmanuals.com
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            • If your driver is not available yet or is not listed yet in the print drivers within Windows 8, you can use "Windows Update" to refresh your printer list. Please follow the steps listed:
              • From "Devices and Printers," click "Add a Printer"
              • Choose a printer port (new or existing)
              • Click the Windows Update button (you must be connected to the internet)
              • After a few minutes, the Manufacturer list will be updated
              • Select Konica, Minolta, or Konica Minolta and find the corresponding driver
              • Install as usual
            The C350 is not listed. You can also try a generic ps driver.
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
                • Install as usual
              Ahhhh, No.
              The C350 doesnt do PS without a fiery / peerless (with PS option) Its PCL only on the standard internal controller.
              • B0265
                • Jan 2007
                • 718
                Have you tried the Vista driver?
                It worked fine in Windows 7 so it might work also in W8.
                • TheOwl
                  • Nov 2008
                  • 1732
                  You can also simply just use an HP Colour Driver.
                  Sure, you lose some functionality of the machine, but that is the price to pay if you don't want to upgrade your machine.
                  Make sure you pick an HP Driver that is PCL5c compatible.
                  • mik77
                    • Sep 2013
                    • 37
                    ciao
                    la devi istallare come hp color laserjet 5500 pcl5
                    • RRodgers
                      • Jun 2009
                      • 1947
                      Originally posted by EarthKmTech
                      Ahhhh, No.
                      Are you sure dude? I'm pretty sure I've set up a few of them with PS without a Fiery.
                      • Blizzoo
                        • Aug 2013
                        • 610
                        PCL 5 if I remember corect
                        • Mr Spock
                          • Aug 2006
                          • 2064
                          From SSD bulletin TAUS0648273EN from 2006
                          The Standard Controller is a PCL controller only.
                          From the service manual dated 2005
                          Printer Languages supported
                          PCL5e emulation
                          PCL6 (XL 2.1) emulation
                          PostScript 3 emulation
                          I do not know who is correct on this one as I do not have any left and have not personally worked on them.
                          • blaze2000
                            • Sep 2010
                            • 232
                            Just an FYI for the C350... 12/2013 is the obsolescence date.
                            • RRodgers
                              • Jun 2009
                              • 1947
                              I'm going to have to let my customer know about that. She does have 3 of them.
