Hi fuser noise from c452c552c series someboday found something ,we keep changing unit and Konicaminolta don t have a difinitive solution
c452 c552 fuser noise
Re: c452 c552 fuser noise
I'm pretty sure there is a tech bulletin on what and where to lube.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
check the drive unit. They used shafts that allow too much play and this causes them to squeak. You need some very thing washers to add to the shafts so they have no "in/out" play. Takes about an hour to remove the assembly. clean it and put it back. I have seen the bearings on the fuser rollers fail very quickly (less then 10k copies) as well.And Star Trek was just a tv show...yeah right!Comment
