C220 freezing when receiving print job
  • Mooseface2r
    • Jan 2011
    • 114
    Hi, i have an issue with a C220 freezing when receiving a print job. it will print the first page but then freeze. so far i have done the following with the same result.:
    Changed network cables
    Tested with crossover cable
    Replaced MFP
    Reloaded Firmware
    Has anyone had this before or can suggest what to try?
    Cheers
    Mooseface
  • JustManuals
    • Jan 2006
    • 9838
    Re: C220 freezing when receiving print job
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • HP:guy
      • Feb 2013
      • 279
      When you say tested with crossover cable was the print successful?
      Have you changed the Driver?
      • Mooseface2r
        • Jan 2011
        • 114
        Tested with crossover cable - it was not successfull.
        have tried a different driver and a different laptop with no joy
        • jjohnston12385
          • 18
          Potential HDD or RAM problem in the copier? I've had HDD problems do some strange things.
          • Mooseface2r
            • Jan 2011
            • 114
            Hi Guys, Changed the hard drive and this solved the problem for about a week and now its doing it again.
            Anyone got any idea what might cause the hardrive to crash out like this? it seems strange that 2 would develop the same fault within a week.
              • 22999
              When you've got Gigabit network capabilities on a 100Megabit switch, this can happen. What you need to do is select the 100MB communication speed from the web interface. =^..^=
              • Mooseface2r
                • Jan 2011
                • 114
                Hi Guys, thanks for the suggestions everythings been tried here.
                Its not throwing up any codes but the job details shows the error as "power off"
                • CrapAimer
                  • 296
                  Have you done the firmware update
                  • Mooseface2r
                    • Jan 2011
                    • 114
                    i have reloaded the firmware...you say "the firmware update" is there one out for this fault?
                    • EarthKmTech
                      Step aside, noob
                      • May 2009
                      • 2139
                      It seems the only thing you havent tried is the ram, which is what i would of tried along with the MFP board for an issue like this.
                      more extreme measures may be needed next if this doesnt resolve the issue.
                      Also, regarding the hard drive, if you replaced it with a KM supplied hitachi it's not unusual for those to fail almost immediately.
                      • dirtyfingers
                        • Sep 2013
                        • 35
                        this might be a strange request
                        But I would change the IP address
                        Did the C220 replace another device ?
                        Did it use the same IP address
                        The C220s are not known for lockups
                        you may find it works fine when you are printing from a crossover cable.
                        if there is a GPI driver pointing to the C220 ...this could cause the panel to freeze.
                        • Avskrap
                          Partner in crime
                          • Jul 2011
                          • 160
                          Is it a PS job from some Linux dist?
                          We've got an ongoing project with the department of computer science at one of the local institutions for higher learning where they've got a C220 that freezes when recieving certain jobs.
                          Konica Minolta have been assisting us and the customer directly, the only solution they've got is special FW (GCD-D1 to be more precise).
                          Apparently Ghostscript is causing these problems and it's ongoing, with newer versions continuing to cause issues and KM can't seem to do anything but to release obscure special FW.
