Bizhub C7000 banner printing (long sheet)
  • Saghir377
    • Feb 2013
    • 47
    [Misc] Bizhub C7000 banner printing (long sheet)
    Hi good after non to all Dear just i want to know Dip switch setting fro long sheet printing from bypass (330mm * 750mm)
    kindly help me
  • CMYK
    Re: Bizhub C7000 banner printing (long sheet)
    Dip switch 10.0
    set the dip switch to '1' (on)
    this then enables the banner mode function under user settings.
    Note machine must be rebooted after banner mode is activated.
    Banner mode maust be turned off and machine rebooted for normal printing
    • geralditec
      Hi, I have a bizhub C6000, with finisher FS-612. I can print 300x900mm banner page but jams/ stops in finisher, and printing completed, so not stuck in fuser, just in finisher, then. I have to remove manually from finisher. Page fully printed but I can't get it to exit properly without doing manually by hand. I did change the dipswitch 10.0 so i can select sizes, just the exiting from finisher that is problem. Do you maybe have any suggestions?
      • obejean
        • Apr 2014
        • 3
        geralditec, you have to remove finisher to do banner printing, only supported with output tray, hope this helps
        • QTab
          Originally posted by CMYK
          Dip switch 10.0
          Can You please tell me where I find this dip switch??
          • Mick01
            • Nov 2012
            • 362
            Hi,
            Dipswitch is acessed from service mode- system setting- software sw setting
            In regards to the finisher jamming issue. It will not jam if the paper weight is set under 135gsm. This weight range will run the engine at full process speed. Any slower it will drop to 2/3 speed and will not exit the finisher in time. If you require paper above this weight then you unfortunately have to remove the finisher.
            Hope this helps.
            • khattab.al.masry
              • 212
              I hope the following attachment that help you.
              and also the following link.
              http://www.copytechnet.com/forums/konica-minolta/21864-bizhub-pro-c6500-banner-printing.html
