Bizhub C352 error S-1
  • eugenionitza
    • Nov 2011
    • 18
    Hi!
    1. Recently my Bizhub C352 shows an error code 'S-1'.
    In the manual it says 'It is detected that the CCD clamp gain adjustment value is faulty'.
    I tried re-plugging the clamps, but the error persists.
    2. Also, when copying a large rectangle appears in the center of the paper, covering the image. (see attached photo)
    Please, give me an advice or a hit that might help me with these issues.
    Thank you,
    Eugen
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Bizhub C352 error S-1
    lamp,mirrors,ccd,slg,memory, or mfp pwb.
    • eugenionitza
      • Nov 2011
      • 18
      I unplugged the clams, I verified the clams and tapes, I re-plugged them and now it displays this error code 'C-9401'.
      The lamp neither moves or lights up.
      Do you think when unplugging I somehow damaged the tape connected to it or should I check something else?
      Thx,
      Eugene
      • eugenionitza
        • Nov 2011
        • 18
        plss help
        thanks
        • Albonline
          • Sep 2008
          • 1132
          replug in the ribbon cable , clean the optics and lasers, run initial setup if this doesn't fix it call in a certified tech.
          • a4o7910
            • 27
            Clean optics
            • eugenionitza
              • Nov 2011
              • 18
              thanks.... I found out that the ribbon was defective.
              Can anyone help me with a spare ribbon cable ?
              I will pay for it.
              Eugene
