C654 with white spots on 2nd side
  • francois
    service manager
    • 32
    Can any one help with a this problem. I have installes a brand new C654e machine and from the first duplex copy i made the machine makes white spots on the second side. i have lowered the 2nd image transfer voltage with no luck at all
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C654 with white spots on 2nd side
    the customer is using low quality paper, this must be addressed.
    every single 4 series will do this if poor quality paper is used.
    • francois
      service manager
      • 32
      Hi, the customer is using 80g normal paper. we tested that paper on a C652 that is standing next to the C654 machine, working ok. even on 120g,160g gloss and bond paper the machine is making the white spots
      • dirtyfingers
        • Sep 2013
        • 35
        There is a KM bulletin for this issue on the C654
        Search KM website for "starry effect (white dots) on reverse side "
        Cause
        Auto mode for 2nd transfer isn't very good
        Changing off auto has shown some good results for me
        There is also SW setting changes in Bulletin
        but I havnt needed to use them yet
        Sorry I don't have the Bulletin number
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • rajabi1367
            • Dec 2015
            • 5
            I have this problem with C754e
            In one-side every thing is OK, but when I print two-side, the first side (which is printed last) is with little dots.
            I have tested on PaperOne and DoubleA papers, the same results
            • copyman
              Owner / Technician
              • Sep 2005
              • 4785
              Problem Solution
              Related Products:bizhub C754e,bizhub C654,bizhub C654e,bizhub C754
              Related Options:
              Problem
              White spots (Starry night) on second side.
              Solution
              CAUSE: Firmware requires updating.
              SOLUTION: Install firmware version K5 or newer and perform the following.
              1. Service mode =>System 2 => software switch change dip switch 59 to hex 01.
              2. Administrator mode => Security Settings =>Security Details. Change the following Engine Dip switches.
              • Engine DipSw 25 to Enable
              • Engine DipSW 26 to Enable
              3. Make the following adjustments in Service Mode =>Image => Process Adjustment
              • Transfer adjust => 2nd side transfer -5
              4. Service mode => Machine => Fusing Temperature
              • Adjust Fuser Temperature to -10
              • Brett GS
                • Jun 2013
                • 154
                Hi all
                I have got the same issue.
                Machine worked fine until a brand new transfer belt was replaced,tried another new belt but no luck.
                I have followed and applied all the above mentioned settings,the paper quality is decent.
                Have the material quality that KM are using on the belts
                nowdays gone down/cheap?.
                Brett
