Scan artefact appearing on Bizhub C220
  • Lord_Azrael
    • Oct 2013
    • 11
    Hi,
    I've got a query with a machine and just thought I'd see if anyone had come across this fault. It's actually an Olivetti MF220 (same as a Konica C220) and when scanning a square artefact appears on the print. It only ocurs with scanning, and doesn't happen all the time.
    Any thoughts as to what could be failing to create this problem?
    Many thanks
    Pictures of problem:
  • dirtyfingers
    • Sep 2013
    • 35
    Re: Scan artefact appearing on Bizhub C220
    looks like image processing
    it could be the memory modules (soldered onto the MFP board )
    Try running the memory checks in service mode.
    Reload firmware
    Compact PDF scanning can also cause some strange effects
    try standard PDF
    My guess is still a faulty MFP board...but rule out the others first.
      • 23008
      I might not be able to tell you what it is, but I can tell you what it isn't.
      It isn't anything to do with the print engine, scanner mechanics, white lever reference, CCD. Which leaves you items that do the image processing: connections, firmware, memory, HDD, scanner PWB, MFP PWB, ... in that order. =^..^=
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Just out of curiosity. If you scan an ordinary document or a picture that does NOT contain a BAR CODE, does the same thing happen? How is this being scanned? Scan to email, folder SMB, FTP?
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
          • 23008
          Do you think the machine is misreading, or trying to obscure the barcode? =^..^=
          • pepper38_cnd
            • Aug 2005
            • 1075
            It may be far fetched but the square sort of resembles those square codes used to scan by smart phones. I was wondering if he had an app on the PC he was scaning to that tried to convert the bar code to one of those things, since both samples he gave us had bar codes..
            • Lord_Azrael
              • Oct 2013
              • 11
              Thanks for all the replies. The MFP board was changed by another engineer last week for this fault, but it still remains, so that should rule that out. I'll have to see if they've been using compact PDF or not and will run the other checks when I get over next week.
              Thanks again, will let you know what happens.
