Pls. help on Bizhub 350 output copy is a little oblique/slanted...how to fix?
  • Bizhub350
    • Oct 2013
    • 11
    Guys please need help on how to fix Bizhub 350 output copy is a little oblique or slanted...thank you
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: Pls. help on Bizhub 350 output copy is a little oblique/slanted...how to fix?
    You take the cover off the front side of elevator, or output tray, and you pull off the gear and belt and put in correct position and reassemble.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
        • 22930
        So ... is it an optical skew from a print, an optical skew from a copy, or a paper skew? =^..^=
        • Don N.
          • Nov 2011
          • 409
          THIS IS YOUR FIX...
          Remove glass and use a hex wrench (maybe 1.5mm? or 1.27?) on front and/or rear black hex screws that have threadlock on them in the CCD/lens box. Twist 1/4 turn cw or ccw and note the change. test, correct as needed. If you go too far, you will see black ribs on edges. Anytime these are rolled around and strongly vibrated, we notice optic skew, even when adjusted correctly, then delivered to customer a bounce on the sidewalk or worse yet, concrete with cobblestone is sure to do it, so be careful when moving! This is a standard part of our refurb process.
          • Bizhub350
            • Oct 2013
            • 11
            it is a skew from a print out but my original is perfectly fine...and I notice if I do a tests pattern copy the turn out is fine and not skew...only when i copy a fine one the output is skew... thanks for all your help guys
            • Hansoon
              • Sep 2007
              • 3349
              Yank up the left front corner of the scanner unit. Somebody was leaning on it and it went down a little.
              This is the most common cause of skewing in the copy mode by all machines of this design starting with the Di-350 through Di-351, Di-3510 series until the BH-350's and likely also the BH-362 series.
              Hans
              “ Sent from my Intel 80286 using MS-DOS 2.0
              https://www.copytechnet.com/images/smilies/biggrin.png
              • Bizhub350
                • Oct 2013
                • 11
                Hansoon tnx it really works Yanking up the left front corner of the scanner unit, now the output copy is A okey no more skew tnx again...your the man...
                • Hansoon
                  • Sep 2007
                  • 3349
                  Glad you solved it and thanks for the feed back.
                  Hans
