C6500 jamming from Tray 2 and 3 ONLY
  • jzheld
    • Sep 2010
    • 162
    [Jamming] C6500 jamming from Tray 2 and 3 ONLY
    Jamming any paper from tray 2 and 3, right after the tray, in the door on the right, took the machine apart changed clutch , gear and sensor, still have the same problem, any suggestions? Picture shows where the paper stops.
  • jzheld
    • Sep 2010
    • 162
    Re: C6500 jamming from Tray 2 and 3 ONLY
    sorry picture is turned
    • seniortech
      • Dec 2007
      • 180
      Jam code?
      • doinbox
        • Jan 2013
        • 113
        Have you marked the rollers to see if they turn?
        Is the door shutting properly? check the claws on the door, make sure there not broke.
        • jzheld
          • Sep 2010
          • 162
          Originally posted by seniortech
          Jam code?
          j-1705
          • jzheld
            • Sep 2010
            • 162
            Just tried that, marked it, and the roller is not moving, what can be the cause?
            • jzheld
              • Sep 2010
              • 162
              I don't know the machine too well. But after checking the service manual I would say you need to replace the registration assembly. It says to replace it after 1,400,000. What is the counter at?
              It's around 3 right now, the only problem, that there is nothing to it, just one roller clutch and the sensor, the rest is just metal, will play around with it tonight
              • doinbox
                • Jan 2013
                • 113
                Ignore my last post. Have you replaced the sensor marked 1 on this picture. It seems to me that the sensor isn't working so the vertical rollers do not attempt to turn. Can you do a sensor check on this model in service mode like the newer konicas. I would say if it doesn't respond and you know the sensor you have fitted is fine it my be the PCRB that has failed.
                • jzheld
                  • Sep 2010
                  • 162
                  [ATTACH=CONFIG]22605[/ATTACH]
                  I just did i/o test for the sensor, it work fine.
                  • jay3
                    • Apr 2017
                    • 46
                    Did you ever get this working? Running into the same issue here with all drawers on the main unit.
                    I've done an I/O check on the vertical conveyor sensor & door sensor - both passed.
                    • Arcadian
                      • Feb 2010
                      • 218
                      i would check the clutches all of them you might have a few other sensors going bad in the ADU main unit there are like 6 clutches in them. check though out if they move when you move the belt most likely they are bad they are not suppose to binding at all.
                      good luck
