bh c220
  • jackson007
    • Jul 2010
    • 114
    [Jamming] bh c220
    hello engineers
    i am facing a problem in my costomers machine bh c220.bypass feed roller is continuosly rotating,so papers are going inside continuously and getting paper jam.
    why feed roller continuosly rotating,i cleand feed clutch also.
  • emujo
    • Jun 2009
    • 3009
    Re: bh c220
    Electrically disconnect the feed clutch, if the roller stops rotating then you have a PRCB problem, or a short in the low active wire. Emujo
      • 23007
      Re: bh c220
      Conversely, if the shaft still rotates after you've disconnected it electrically, you've got a seized clutch. =^..^=
      • jackson007
        • Jul 2010
        • 114
        Re: bh c220
        i removed connection then cheaked.clutch still rotating so i desided as clutch was stucked
        thanks for responded engineers
        • JustManuals
          • Jan 2006
          • 9838
          Re: bh c220
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          http://www.justmanuals.com
          paul@justmanuals.com
