601 no heat and freezing SM?
  • Synaux
    • Mar 2012
    • 1224
    I got a 601 that the !@#$ing web roller wrapped around the upper fuser roller (my fault for leaving slack like a moron--this is why I avoid work when feeling crapulous).
    Okay, so I did something stupid, but I got that nasty stuff out of the roller with some care and performed a full PM (including drum and developer) and installed a new web roller all at once.
    Now, the entire fuser section will not heat up at all.
    I get alternating 3901 and 3803 codes which is entirely understandable as they are codes for the thermistor not reporting an adequate heat level.
    Fusing section not heating aside, in Service Mode, when I attempt to do anything I am prompted with "please wait 3901 [or 3801]" and becomes unresponsive. Obviously, I cannot flash the firmware via USB at this point and internet ISW is not possible as the controller is not fully engaging (if at all).
    I have physically checked the entire fusing unit, PRCB and wiring and everything looks
  • blaze2000
    • Sep 2010
    • 232
    Re: 601 no heat and freezing SM?
    Those are fuser errors so be sure to set dip switch 3-1 to zero to reset the machine. Also, you may have to boot directly into service mode.
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        I would check each lamp with a meter, then change the thermistors. How does the plug in for the fuser look, maybe a pinched wire? Odds are, If it worked before you touched it, it is something you touched.
        • Synaux
          • Mar 2012
          • 1224
          Thanks guys, I got it.
          It was definitely the firmware! I was able to get into the trouble reset mode (press the utility button and hold it before pressing the sub power switch next to the panel).
          I was able to successfully write the MFP-20 firmware to it (although, the finisher option wasn't available, but did it afterward).
          Fixing section fully operational now.
          Yes, I did want to set the dip switch, but I couldn't get SM to respond.
          Now, I cannot print to it for some reason.
          I initialized the network, have the correct network settings and able to ping it also tried LPR and RAW port settings...?
          Edit: Might be worth noting that SMB scans work.
          • Synaux
            • Mar 2012
            • 1224
            Formatted the HDD and printing works. doh
            The only other thing is that there are no options in the finisher section (service mode and administrator/expert mode).
