Close section properly c350
  • copierlady
    • 338
    Hey guys,
    working on a biz hub 350.
    When you put paper in the adf, the machine has "close section properly" message. N it is indicating to close the whole adf section, not just the feeder section on the left. Both sections are closed, i can see nothing indicating a problem.
    Any ideas out there? Do ya even remember this machine? Seems like a problem i dealt with a long time ago, but i can't remember what the solution was?
    • 14513
    Re: Close section properly c350
    Make sure the DF is straight. The magnet on the DF has to line up with reed switch under the front scanner cover.
    Hope this helps
    Darren
    • emujo
      • Jun 2009
      • 3009
      Haven't worked on a C350, but the newer models use a combo of sensors and the CCD to determine paper size of the glass, possibly you have a bad sensor causing the MFP to mis-detect something on the platen. You should be able to verify by putting LT on the glass, lower the feeder until lamp turns on, and watch to see what size is detected. If it sees the paper, but mis detects the width, then it's CCD, length would be one of the sensors. Emujo
      • darry1322
        • Oct 2010
        • 817
        Hope this helps
        Darren
        My money is on this..I've seen it a few times. User grabs doc feed to move the copier and eventually it gets out of alignment.
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          paul@justmanuals.com
          • copierlady
            • 338
            Re: THANKS
            Thanks for your help. The problem was the magnet and the switch. Off just a hair and the screws in the henge were loose.
            Thanks again
