Bizhub 350 web interface not available
  • joneze
    • Aug 2007
    • 128
    Got mine sorted by using total clear on the machine.
    • SomeDude
      This is not a fix, but it may give a clue to somebody who *can* help us: If I go into Windows Explorer - NOT IE - and type the IP address without a leading '\\' or anything else, an IE window is launched that says the page can't be found. BUT, if you look closely, you can see that the 'back' arrow is enabled. Using that, I can see ~part~ of the Web-based UI page. What could possibly be causing such a thing?!?!?!
      • TheOwl
        • Nov 2008
        • 1732
        Don't know about the rest of the world, but here in Australia we have this problem as well.
        What it is here is simply upgrading the firmware on the machine to version 70 or later.
        The underlying problem is .Net Framework 3 and up. When using Internet Explorer, .Net Framework runs in the background when viewing webpages, but the machines weren't able to understand the requests unless you upgraded the firmware. If you are using .Net Framework 2 and below, you would find that everything is ok.
        The other thing you can do is try using Firefox, but I have had a case where this didn't work either, so the firmware upgrade was necessary.
        • stathistec
          • Nov 2008
          • 17
          #19
          i had the same problem
          the only way is to update/reinstall the firmware of the machine with SD cart
          • copiercopy
            #20
            HELP
            I want to down my copier counter C450 bizhub
            • dogsbody
              • Jun 2007
              • 289
              #21
              if you are looking to reduce the counter on your machine you are looking in the wrong place
              The force will be with you always.
              • copiercopy
                #22
                ok
                i have a machine (C450 bizhub) and iwant to buy it but nobody dont buy it becaude it counter to mach 800000
                • dogsbody
                  • Jun 2007
                  • 289
                  #23
                  I can't make much sense out of that.
                  If you have a issue i suggest you start your own thread instead of hijacking someone elses.
                  • iso8859
                    #24
                    Re: Bizhub 350 web interface not available
                    C353 reply a page that seem empty.
                    But if you look at it you can read a redirect to top.xml
                    Open http://192.168.x.y/wcd/top.xml and it works !
                    Remi
