Konica/Minolta Bizhub 420 cannot scan
  • jasonemmg
    • Aug 2025
    I have a Konica/Minolta bizhub 420.
    I have been able to scan and e-mail documents from the copier to my PC and others in the office.
    For some reason or other today I am only able to scan to e-mail not to the "scan docs" folder set up on my PC or others.
    HELP PLEASE!!!
    Jason
  • bgbas
    • Feb 2007
    • 60
    What kind of scanning? FTP to a shared server folder? SMB? Box Operator?
    • jasonemmg
      I am scanning SMB to a shared folder on my PC. It worked 2 weeks ago when I last needed to scan a document.
      I have scan to e-mail set up for myself so I used that yesterday until I fix the scanning.
      Thank you!
      • NotByChoice
        • 39
        Do you get any error messages?
        If you changed your network password you will have to re-enter it. You can do so with a web browser by going to http://the-printers-IP
        If the computers hostname or IP changed you will have to update that as well.
        Check all the network settings and make sure it's all correct.
        Check the permissions on the folders on the computers and make sure that appropriate rights are given so the scanner can access it.
        • jasonemmg
          I am getting a message "job not done properly". I spoke to a support person, they suggested also going through the setting on both the copier and my PC as well as others.
          • dogsbody
            • Jun 2007
            • 289
            go to the job list, press scan, press history, find an smb scan that didn't work and press detail, here you find error details like login error, server connect error, folder cannot be found etc. when you find this you have a place to start troubleshooting.
            The force will be with you always.
            • jasonemmg
              Thank you to all for your assistance.
              Yesterday afternoon the copier decided to scan documents once again???
              Jason
              • NotByChoice
                • 39
                Must be a network issue then
                Jason
