Black problem on C550
  • Dahummer
    • Aug 2025
    [Misc] Black problem on C550
    Hi
    I had this black toner is low message on my C550 in the meantime it started fading away, so i replaced it with new one, the message disapeared but problem is I only printed like 20 pages and its gone, colors working fine, any idea how to fix this ?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Black problem on C550
    paul@justmanuals.com
    • blaze2000
      • Sep 2010
      • 232
      First thing you may want to do is check your black IU. Make sure it is dumping developer, if so machine will need cleaning and IU will need replacemnt.
      • Dahummer
        hi
        i changed black IU and it works but after turning off the machine and on the black faded away again, here are 2 test pages
        REGARDS
        • Synaux
          • Mar 2012
          • 1224
          Originally posted by Dahummer
          hi
          REGARDS
          Sometimes you have to manually supply toner in service mode (only do it 3 times). If this doesn't work get a funnel and add toner to the black IU.
          You might also have a failing hopper unit. You can take the units out and switch the black unit with a different color after a thorough cleaning.
          Might want to consider the HV board and the mod for the latch on these machines.
          Hope this helps.
          • copier tech
            • 8187
            This is not a toner supply issue, especially as you say the m/c prints ok then all you do is power off/on & the m/c stops printing black?
            i'd suspect the PH unit
            • Dahummer
              hi again
              as you see on test pages the first one when i installed a new black IU and print few pages, the second one after turn it off and on .
              • copier tech
                • 8187
                You'd have to run 100's of pages to run the dev unit completley empty of toner.
                • Synaux
                  • Mar 2012
                  • 1224
                  This is not a toner supply issue, ...
                  Good call seeing how you are not in front of this machine.
                  Regardless of correctness, one should refrain from resorting to absolutes.
                  Dahummer, did you perform an Initialize and Stabilization?
                  If so, I say HV board before PH unit, but if you have a PH unit to switch out that is probably the easiest and quickest item to rule out (other slight chance you have a malfunctioning transfer belt I guess).
                  Also, did you shake the IU before installing it?
                  • Dahummer
                    yes i did Initialize and Stabilization, thanks
                    • ajim shine
                      • Apr 2014
                      • 6
                      try check dv motor.. last time i got same problem.... motor shaft was broken......
                      • Rolandito
                        • Aug 2007
                        • 91
                        1st.. clean glass of ph unit....
                        2nd.. install lastest firmware..
