error code c 5501
  • kamoga
    • Jun 2013
    • 36
    error code c 5501
    Hi all iam brian
    and i have a machine biz hub c220 which has an error code
    C-5501(Ac signal abnormality) i have changed the DCPU,PRCB,and
    even the fusing unit but it has failed.
    some help
    thanks for the reply
  • JustManuals
    • Jan 2006
    • 9838
    Re: error code c 5501
    paul@justmanuals.com
    • MrIcka
      • May 2017
      • 4
      Hi,
      Didier you ever find a solution to this error?
      I have a New C458 that have the same error and I have changed the same things as you according to the service manual.
      Help!
      • Bix
        • Apr 2018
        • 1421
        Hello, the problem can be reset with a simple switch on / off (wait 10 seconds before doing it again on).
        If the problem persists, check the correct insertion of the fuser unit.
        Also verify that the DCPU and MFPB are connected correctly.
        • Synthohol
          Certified Konica Expert
          • 5926
          Error
          C5501
          Root Cause
          C5501 shortly after power up or during operation.
          Workaround/Fix
          CAUSE: Irregular voltage from the power supply. MFP controller firmware patch update is required.
          SOLUTION: Install MFP controller firmware patch version G12-01. This firmware patch will overwrite the printer firmware only. It can be used in versions up to and including G00-B4 to eliminate the detection of a DCPU abnormality (C5501).
          IMPORTANT: This firmware eliminates the detection of a DCPU abnormality (C5501). If the fusing heater control does not detect an abnormal power supply frequency, a fusing temperature error malfunction code might be generated. (C37xx, C38xx or C39xx)
          Note: The latest version firmware or system software is available via One stop Product Support.
          To load patch
          1. Unzip TAR file to USB thumb drive root directory.
          2. Install thumb drive in service USB port.
          3. Power ON machine.
          4. Firmware load screen displays on panel.
          5. Select printer YES.
          6. Press Start button.
          7. Select END when checksum appears.
          8. Power cycle MFP.
          • AjitN
            • Mar 2009
            • 287
            Originally posted by kamoga
            Hi all iam brian
            some help
            I think this could be because of A/C mains power, Either fluctuating very fast OR there are spikes.
            Try another supply point or add stabilizer.
            Hope this helps
            • tech51
              • 846
              Originally posted by Synthohol
              Error
              C5501
              Root Cause
              Workaround/Fix
              To load patch
              8. Power cycle MFP.
              I believe this is the procedure for the c220, however MrIcka has the problem on a C458.
              It would have been better to start a new thread MrIcka rather than hijack an old one.
              You will get more relevant advice that way.
              • Ricardo_Reis
                • 13
                Hi, how are you? I have this problem on a BH C454E, all the steps in the service manual were done and the code persists.
                Can you send me the firmware patch version G12-01?
                follow my email: ricardosantosr@hotmail.com
                Error
                C5501
                Root Cause
                Workaround/Fix
                To load patch
                8. Power cycle MFP.
                • Synthohol
                  • 5926
                  i have been on disability for over a year and i no longer have KM access to anything.
                  • tsbservice
                    Field tech
                    • 8083
                    Wish you recovery soon but why they suspended your account I see here many people with access to MKM and literally zero interest and knowledge... Anyway count on me anytime you need anything I can help with.
