C351 test toner motor?
  • mrfuser
    • 1603
    Is there any way in service mode to test that the toner motor is turning on a bizhub c351?
    been a while and I can't see I/o in servce mode.
    kelly
  • JustManuals
    • Jan 2006
    • 9838
    Re: C351 test toner motor?
    http://www.justmanuals.com
    Paul@justmanuals.com
    • Blizzoo
      • Aug 2013
      • 594
      1. Call the Service Mode to the screen.
      2. Touch these keys in this order: [Imaging Process Adjustment] → [TCR Toner Supply].
      3. Select the color, for which supply of toner is to be replenished.
      4. Pressing the Start key will let the machine detect the current toner density and; if the
      density is lower than a reference value, a toner replenishing sequence and then a
      developer agitation sequence are run.
      5. These sequences are repeated up to a maximum of four times until the toner density
      reaches the reference value. If the toner density is found to be higher than the reference
      value, only a developer agitation sequence is carried out.
      I don't have the c351 manual,but i think this section above is on all colors
