Bizihub C200
  • andy227
    • Jan 2013
    • 219
    Bizihub C200
    Hi guys. Some colleagues with a KM Bizhub C200 are getting these multiple evenly spaced lines when only when photocopying color, not when printing from computer or memory. They've changed the entire scanner unit and its still the same. Anyone come across this, and any ideas ? Sample attached (I hope),
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizihub C200
    paul@justmanuals.com
    • blaze2000
      • Sep 2010
      • 232
      Re: Bizihub C200
      Not sure what is exactly meant by changing the entire scanning unit. I'm assuming that would include the CCD and whole nine up top. I'm thinkin a bad connection or bad board... this attached page might give some help or guidance.
      • andy227
        • Jan 2013
        • 219
        Re: Bizihub C200
        yes, the whole thing. Not sure whats going on here, but yours, and other attachments are not opening lately. Is it just me with this problem ?
        • RRodgers
          • Jun 2009
          • 1947
          Re: Bizihub C200
          I don't remember if the connection for the main body is the male end or female end for the scanner. Maybe check for bent pin's but that will usually give you a background of one color. Try swapping ram with another machine.
            • 23009
            Re: Bizihub C200
            It looks like the lines of shame. =^..^=
            • RRodgers
              • Jun 2009
              • 1947
              Re: Bizihub C200
              I miss the Like button.
              • andy227
                • Jan 2013
                • 219
                Re: Bizihub C200
                Please elaborate...............?
                  • 23009
                  Re: Bizihub C200
                  The "Lines Of Shame" are what you get when you do not do a complete setup on a Konica Minolta color MFP.
                  Some people think: "I can just skip a bunch of those steps .. they're not really necessary." If you skip some of the steps in calibrating, the machine will print lines at ~10mm intervals in the feed direction. It's Konica Minolta's way of saying: Dumbass! Do it right!
                  The cure is to find yourself a setup checklist. Start at the point where you plug in the machine. Do all the steps from there on.
                  The lines are usually magenta or cyan, but I understand that they can also be yellow or black.
                  • RRodgers
                    • Jun 2009
                    • 1947
                    Re: Bizihub C200
                    Guess I've always set mine up correctly and have never seen um!! ha ha!
                      • 23009
                      Re: Bizihub C200
                      I've seen them exactly twice. Each time I was working in the office, with the usual hundreds of interruptions, so I had no real idea what had been done and what hadn't.
                      When I was in class all the machines were making the lines upon arrival. I had the pleasure of fixing a bunch of things on our classroom machine. =^..^=
                      • mik77
                        • Sep 2013
                        • 37
                        Re: Bizihub C200
                        ciao
                        prova a fare l'stallazione iniziale della macchina. come se fosse nuova.
                        segui il manuale alla lettera
                        hello
                        try to do the initial installation of the machine. as if it were new.
                        follow the manual to the letter
