bizhub c280 with 72-16 jams
  • teckmate
    • Mar 2010
    • 4
    [Jamming] bizhub c280 with 72-16 jams
    Intermittent and only on 2 sided copies. Page makes it though fuser but gets folded as it enters next baffle ( like lead edge is hitting baffle and folding over ). This is actually an OCE machine but same as bzc280. Paper quality ??
  • xscotty1990
    • Nov 2013
    • 40
    Re: bizhub c280 with 72-16 jams
    Hello teckmate,
    try checking fuser exit section, there is maybe some condensation water on the black baffle.
    Maybe damp paper?
    Greetz
    Marco
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      72-xx jams are finisher jams.
      What finisher is installed on this machine ?
      • wseyller
        • Sep 2012
        • 1129
        Test from each tray and see if it exclusive to happen with only one. There was someone else that had the issue and it was the LCC tray out of alignment.
        Sent from my DROID BIONIC using Tapatalk
        • JustManuals
          • Jan 2006
          • 9838
          paul@justmanuals.com
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            Try removing that bridge unit, the inner transport unit. Clean the conveyance rollers off. Had some like that that would jam paper. Dirty rollers In there wouldn't grip.
            • blaze2000
              • Sep 2010
              • 232
              Could be failed switchback gate control.
              Check the switchback gate for dragging, staying up or increased tension and replace Switch Solenoid (SD1) if necessary (p/n 9321 2200 32).
              Check/inspect the Pulling Spring. If the pulling spring has failed, replace it (p/n A00J 8938 00).
              • Arez
                • Nov 2009
                • 2
                in my case it was reg roller sensor, which actuator doesen`t work properly.
                • paulinho
                  • Jul 2010
                  • 9
                  Hi teckmate. Did you manage to fix this issue? If so are you able to shed some light as to your fix. I currently have a C360 doing the exact same thing. Any info would be greatly appreciated.
                  • copier tech
                    • 8132
                    I've found 9/10 this is a paper issue, if the paper is damp or of poor quality it will curl, especially on duplex, then will jam, usually after the fuser or in this case the finisher.
                    So you get j7216 finisher or j3205 fuser jams
                    • Zeldaman
                      • Mar 2011
                      • 946
