BizhubC250: how to see the toner's level thx!
  • sami42
    • Aug 2025
    hello, I would like to know if there is a function on the bizhub C250 which allows to know the level of toners ie the amount consumed and remaining (one for each color gauge BCMY?)
    thank you in advance!
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    If you have the machine networked, you can view an embedded web page by opening an internet browser and type in the I.P. address in the address bar. There should be an estimated toner remaining section that gives you a general estimate of toner left in the cartridge.
    • ebm
      • Apr 2007
      • 183
      If you press Utility/Counter button there should be a "Check Consumable Life" displayed on the touch screen. If it is not displayed in the Utility/Counter mode then check in the "Administrator" mode.
      • sami42
        thanks fo yours answer! i gone try it!
        • ni311
          • May 2008
          • 658
          The "Check Consumable Life" is showing only the life on imaging units, fusing unit and transfer belt, you won't see any toner level there. As cobiray said, the only way to check it is to open the web page of the machine with your browser. The later models, C203/253/353 have small icons that indicate the toner level, but unfortunately C250/252 have no easy way to check it.
          Konica Minolta Error Codes - Explanations and Solutions
          • sami42
            thanx ni311, i think that i'll use a rudimentary method on a super sophisticated machine!
            I will remove the toner shaking, weigh ....
            thx!
