bizhub 350 adf jam, totally lost
  • pager727
    • Aug 2013
    • 21
    [Jamming] bizhub 350 adf jam, totally lost
    I have a bizhub 350 with the df-605, it is jamming intermittently, i have replaced the feed tires and sep tire and now at a loss.. any ideas?
    Thanks!
    • 14903
    Re: bizhub 350 adf jam, totally lost
    If you could let us know where in the DF the jams are occurring and/or the jam code, that would be very useful in trying to troubleshoot your problem.
    Darren
    • JustManuals
      • Jan 2006
      • 9838
      http://www.justmanuals.com
      paul@justmanuals.com
      • pager727
        • Aug 2013
        • 21
        it happens right before the transport rollers, i believe the one way gear on the transport rollers is slipping
        • Shadow
          PHD in Sh!t Disturbing
          • Sep 2011
          • 455
          you will need to remove the shaft completely and the bearing as well.
          take some emery cloth and lightly scuff cross ways on the shaft to remove the glazing.
          clean the one way bearing with alcohol and the end of the shaft as well.
          reassemble the unit and test operations.
          I can't remember if there are 1 or 2 one way bearings in that particular DF, if there is more than 1, do them all.
          this will help improve the paper feed in this model DF.
          $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
          • rahadyan himura
            • Jun 2012
            • 21
            Thanks!
            maybe your problem from drive section, you can check (4344 5059 01) TORSION SPRING at rear RADF, i face this problem and found the torsion spring is broken. checking at drive section and you can find your solution.
            i hope this can help you
            rahadyan
            • ameritech
              • 96
              I had a bushing on one of the roller shaft that was worn down. I had to replace bushing and the shaft. Thr Only
              Issue I had with with the 350 adfs.
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                There are 2 photocells detecting entry and exit. If they are dusty, it will jam.
